Question about Garden
For a Poulaln P3314 what position should the movable safety bar be for starting, forward toward the chain/bar, or rearward toward grip. Ted
    President:
  • 583 Answers
The safety bar is chainbrake and should be in off position so the chain is free to move on the bar,,, that should be to the rear youdoit
Posted on Jul 27, 2009
  • kerry littleton Jul 27, 2009
    the safety bar is chainbrake and should be in off position so the chain is free to move on the bar,,, that should be to the rear youdoit
I have a Remington electric versa saw rm1635w and the chain won't spin around the bar what do I need to get it running again
there is a safety clutch that you disengage when finishing the cut
it disengages the chain from the motor drive by a dog clutch
pull the safety bar back towards the trigger and the chain will cut
if you leave the finger on the trigger and the chain jams in the cut , you push the bar forward and the motor spins free
if that doesn't work take it in for a fix as that clutch is failed
Nov 16, 2016 | Remington Garden
Why doesn't chain move?
pull the safety bar back towards the handle
it is a safety clutch and when pushed forward stops the chain from moving
Nov 17, 2015 | Poulan Pro Pp4218av 18" Gas Chain Saw...
On Homelight 3816c what is the position position of chain brake when cutting
Easy enough to test which position is correct. With the saw not running of course, Try each position the one where the chain moves freely is the correct position. Most likely on this saw it will away from the bar (rearward).
Nov 16, 2014 | Garden
I have a chain saw 55 husqvarna and while the motor turn he stop suddenly often of the time when I put the brake and the motor is truning slowly he stop
Check to make sure the brake binder is not engaged...which is the same as saying: check and make sure the kickback brake handle is fully cocked. The handle should be oriented rearward towards the forward hand grip. If it is forward, pull it back stongly until it lockes in place. (Hint: also make sure the binder is released/brake cocked always before attempting to remove the brake assembly from the saw drive engine subassembly.)
Oct 04, 2014 | Husqvarna Chain Saw Models 51, 55
I have a 32cc model p3314 it starts but the chain won't move
If you are talking chain saw there is a safety clutch lever immediately in front of the top handle. this has to be back against the handle and when the chain jams you simply push it forward with your fingers and the chain stops
May 29, 2013 | Tools & Hardware - Others
What is the shape of the handle bars on the Schwinn High Timber Girl's bike?
These are certainly not racing style bars; but the modern, hybrid riser handlebar.
They will not sweep back toward the rider as much as a beach cruiser handlebar; but could be adjusted rearward to come closer to the rider. They definitely allow for a more upright riding position than many other handlebars though.10_19_2012_7_26_19_pm.jpg
Oct 19, 2012 | Schwinn High Timber Girls' Mountain Bike...
Yesterday around five i was chopping some logs out of a small tree i felled. i was doing a under cut to the top tru a small bout three inch tree. next thing i know my blade isnt spinning. so i stoped for...
I don't have any poulan saws mine are all stihl and homelite but they all have a chain lock on them .It is located on the front of the motor on top of the saw and if they are hit fairly hard they will lock down on the chain to prevent injury. Try to push the bar forward then pull it back towards the rear of the saw. You should hear it click when it resets.Hope this helps you. Thank you
Jan 06, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
The engine will start but the sprocket will not turn it appears to be something with the clutch
Check and make sure your chain brake is in the OFF position
Pulled back towards the operator
Mar 29, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Chain saw motor runs but chain doesn't
There are a couple of reason the saw blade will not turn.
- Make sure you have bar and chain oil in saw.
-Make sure oil is running on the saw blade and chain.
-Make sure the clutch is not stuck.
- Make sure the bar sprocket is not frozen.
-The safety kick back guard needs to be re-set.
-Shut off saw. Push and pull guard.
Please let me know what you find.
Feb 10, 2010 | Garden
I can start chain saw but cannot get chain and blade to move. What would be causing this
Check the chain brake safety mechanism, see if it is jammed or see if chain has come out of track...
Aug 04, 2009 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
