Question about Electrolux Cooktops
I have an Westinghouse/electrolux ceramic cooktop model PHH285W. When I turn on one of the elements it is full on no variability at all. Is this a thermostat or something? Can I purchase a new part and fix myself?
ranger25
  • 72 Answers
SOURCE: Kenmore Radiant Ele Cooktop
They have a thermal overload resistor in the burner itself and they have a propensity to burn out, making it either all off or on, or it could be the infinite switch. I would check the resistor first. All the way cool you should get close to no resistance. Heat it up with a blow dryer and there should be more resistance. For the infinite switch, you will have to check resistance across the leads that correspond to each pinout as to what it goes to. You can find this out by backtracing the wire to each terminal on the block. Replacement of either part is the only option, there are no safe alternatives to repair them. Hope this helps. BTW, you can go here for parts.
www.appliancepartsdepot.com
Posted on Jan 28, 2008
  • 93 Answers
SOURCE: Gagganau Glass Cooktop
www.foxatlanta.com
Posted on Jul 21, 2008
  • 491 Answers
SOURCE: Hi my name is Ursula I have a 5 burner ceramic
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Posted on Oct 13, 2009
  • 159 Answers
SOURCE: westinghouse freestyle 521 stove ceramic
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
Posted on May 29, 2010
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
Apr 22, 2014 | Whirlpool Cooktops
Westinghouse freestyle 521 stove ceramic top.elements wont turn down no matter where switch is. burns food. Have used different size pans etc,
May 29, 2010 | Cooktops
Double ring burner won't light up.
the outer element may be broken if the center one is the only one getting hot
Apr 07, 2010 | Electrolux 23 in. EHD6670P Electric...
Whirlpool induction ceramic cooktop error E6
Dec 15, 2009 | Cooktops
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Cooktops Logo
143 people viewed this question
Top Electrolux Cooktops Experts
rugby prop
Paul Carew
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
