Question about Dryers
Dryer start up fine then the gas turns off as ignitor continues
Looking at some of the other posts, I have taken the front bottom cover off to obswerve the process. Initially, the Amana ALG443RAW starts the heating process, the gas lights. After a few minutes, the gas turns off. The ignitor light continues to cycle but the gas is not lighting and therefore no more heat? What can I check that would continue the heat cycle? I have the dryer set to timed drying. In another post, someone said that would keep the heat going for a timer based period.
Thanks,
Jim
  • 10,865 Answers
Hi Jim. Perhaps this will help you.
The burner assembly consists of the gas valve, the igniter and sensor, and the thermostats. The gas supplied to the appliance is turned on and off by the gas valve, as follows:
  • First--when you close the dryer door, set the timer, and press or turn the Start button--the motor starts. When it reaches full speed (in about a second) a switch on the motor turns on, which allows the electricity to flow through a simple thermostat to one side of the gas valve.
  • The gas valve then sends power to the igniter, which glows bright orange.
  • As heat and light from the igniter warm up a sensor that's right next to the igniter, the sensor circuit opens, then supplies power to the other side of the gas valve. This completes the circuit and opens the valve.
  • Once the valve opens, the gas rushes out and the igniter ignites it. As the gas burns, it keeps the sensor warm, which keeps the gas flowing.
  • When the dryer reaches the pre-set drying temperature, a simple thermostat turns off the flow of electricity to the gas valve and therefore turns off the gas.
  • When the temperature in the dryer falls about 20 to 30 degrees, the thermostat again allows the electricity to flow through to the gas valve, and the cycle starts over.
If you selected the Automatic setting, the cycle continues until the clothes are dry, then the timer advances and turns the dryer off.
If you selected a timed setting, the cycle continues until the time has expired, then the timer turns off the dryer
Posted on Jul 27, 2009
    President:
  • 1,776 Answers
It sounds like the problem could be faulty gas valve coils. When the coils are energized they open the gas valves. If defective, the ignitor will operate, but the valves don't open and the gas cannot ignite. Because it is difficult to test the coils, it is usually wise to replace both or all of them at the same time. Hope this helped and best wishes.
I have a GE gas dryer DBVH512GF1WW. The heat is inconsistent. I noticed the ignitor glowing and then a flame shortly after on the initial time I turned the dryer on. Then after the flame going out after...
sounds like bad gas coils located on top of the gas valve,when the coils start to fail the ignitor will glow,the coils let the gas in until the coils heat up and then ignitor glows but no gas.when the coils cool down they might work again for a short time until they heat up and fail again.if the flame lights and goes out after like 30 seconds and goes out and keeps doing this you have a block either in the dryer or the vent line but it sounds like you have bad gas coils.unplug the dryer,get at the valve,pull off the wires going to the coils and check them with a meter,one should be open,just remove the two phillips screws pull off the cover and slide the coils up off of the posts,unplug them and put the new coils on,you'll see like a little piece of plastic on the top of the coils,this fits intoo the cover so they line up correctly and holds them in place,also on the larger coil there's a spacer on the post,if you don't see it look inside the old coil,poke out the spacer and slide it onto the post and then install the coil.
Oct 23, 2013 | GE Dryers
Dryer wont heat up
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. In some cases the ignitor or the gas coils will go bad. Here is a good process of elimination.
1)Verify that the thermal fuse is good. If you don't have a meter bypass it and turn the machine on. If heats, thermal fuse is bad, if not leave connected and continue
2)When the dryer starts and thermal fuse bypassed, the ignitor should start to get hot and glow, if your thermal fuse is in the back you are going to have to have to the top of the dryer up to see down inside near the front for the glow. You can do this by taking the lint trap out and removing the two screws and popping the top up. If the ignitor comes on more than likely the gas coils are bad and if it doesn't the ignitior is bad. (this is while the thermal fuse is bypassed so the ignitor has power to it regardless)
Jun 05, 2012 | LG DLG5932S Gas Dryer
Whirlpool gas dryer will not get hot
May 22, 2012 | Dryers
Dryer tumbles no heat
remove the top cover,then the front cover,then check the burner tubes ignitor or glo-bar that ignites the gas,the high-limit thermostat on the burner tube for continuity,the thermal fuse and cycling switch on the blower housing both of these should show continuity or good like a standard fuse would show
Nov 18, 2010 | Kenmore 74642 Gas Dryer
I AM LOOKING FOR THE SCHEMATICS ON A ROPER DRYER MODEL # RGL4632BQ0, CAN YOU PROVIDE ME WITH THAT INFORMATION? MANUALS ONLINE DOES NOT HAVE THAT MODEL OR ANY OTHER FOR THAT MATTER. I HAVE TO PUT IN A GAS...
Before attempting to buy the ignitor or any other part take the back off and check the fuse. 958e138.jpgNote: on gas models this fuse kills the power to the burner unit only. If its bad you needs ta clean out the filter chute. Remove it From the dryer and wash it out. Remove sand and lint from blower area etc. If that is ok then you need to take a look at the burner assembly. efaa486.jpgCheck the igniter for continuity if open it is bad, check the flame detection unit if this is open then the ignitor won't fire off. Don't touch the ignitor silicone carbide filement or it will be ruined. Service manual
Wiring diagram
Apr 08, 2010 | Dryers
Dryer barrel turns no heat this is a gas dryer 90 series kenmore
remove front cover, this will allow you to remove top cover, then take off drum belt and you will see the gas valve,follow the gas tube to the fire funnel and you will see the ignitor, check for continuity, if its good, then it could be a flame sensor or the control board at fault
Sep 24, 2009 | Kenmore 75944 Gas Dryer
Hot water heater went out when they replaced our dryer doesn't
Make sure the gas valve at the dryer is turned on. Dryers use a glow plug or electronic ignitor to light the gas. There is no pilot light. Plug the dryer in and start it. Look inside the front lower panel to see if the ignitor glows. If it does and the gas does not light then the gas to the dryer is probably turned off. Look for a valve in the supply line to the dryer. Also inside near the front underneath.
Aug 05, 2009 | Dryers
No heat
Should be a cover about the size of a quarter on the front lleft bottom...pop off with a small screwdriver and start dryer....look inside and see if the glow bar lights up...if glow bright orange, probably good, may need gas solenoids or ignitor
Jun 10, 2009 | Whirlpool LGB6300 Gas Dryer
No heat
If your dryer has an access panel at the bottom front remove it.  Start the dryer in a cycle and watch the burner area. You should see the ignitor start to glow. After a few seconds of it glowing you should hear a click and the gas come on and ignite. If the ignitor does not glow, look on the top of the air duct to the left of the gas valve. You will see 2 temp sensors. One will be white with  2 small blue wires going to it.    UNPLUG THE DRYER NOW    Remove the wires and connect them together.   BE SURE THEY DO NOT TOUCH ANYTHING ELSE
Plug dryer back in and start dryer again and see if ignitor glows and burner lights. If it works now, you need a new thermal fuse. You also want to make sure the vent duct is not clogged with lint or the hose is not kinked.  I DO NOT recommend that you run the dryer with this bypassed. It is a safety mechanism.
If this is not the problem or your dryer is not front servicable, post back and i will try to walk you through the problem.
Oct 11, 2007 | Dryers
LG DRYER DLG2532W GAS
I had similar problem with my LG DLG2532W gas dryer:
1) Power on machine:
- Check Filter light comes on (LG says this is OK at start)
- Time lights have all dashes
- All Program cycle lights on (Air Dry up to cotton towels)
- This is all normal
2) Select program cycle (cotton towels for example)
- Check Filter light now goes off
- Time shows 58 minutes
- Dry Level, Temp Control, etc are set automatically
3) Push start (this is where the trouble begins)
- The "drying cycle" light starts blinking (good)
- The dryer starts turning (this looks good...but)
- The ignitor (heating coil that ignites the gas) never heats
- The gas never comes on (because ignitor not on)
- No heat ever is produced.
Net result is dryer looks normal and runs, but there is no heat.
There is no error code...nothing to tell you anything is wrong.
Your only recourse is to call a technician because the manuals do not explain anything in any detail.
Thank goodness for the internet. I just needed the one clue that there was a reset button on the thermostat. That fixed my problem. Here is some more detail in case someone else is having this problem:
There are apparently two thermostats in the dryer. They are on the exhast tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button. Before pushing the reset button PULL THE PLUG ON THE DRYER OR TURN OFF CURCUIT BREAKER. The reset switch is between two wire leads that go to the thermostat and you will probably shock yourself if you try to push the button with the power on. If you open up the right side access cover on the dryer, then you can see the exhast tube. It is about 5 inches in diameter and (looking thru the right side access port), it will be sloping up from left to right as it runs from the front of the dryer to the back. You can see another exhaust tube further away from the port and lower down, but the one you are looking for is closest to you and higher up. If you look back toward the front of the machine (left), you can see two wires hanging down from the opposite side of the exhaust tube. The wires run to the thermostat which you can also see on a bracket standing off the exhaust tube. In between the two wire leads that run to the thermostat is the reset button.
Bottom line....pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minuite operation if you can get to the right side access port.
If you cannot get to the right side access port, you can pull off the fronf of the dryer and get to it that way, but it is much harder. You start by popping the dryer top by pushing in a putty knife between the top cover and front cover about two inches away from the top left and right edges of the machine. This is tricky and takes some fidling. I just pryed mine open the first time, but now I see how it is supposed to be done. After popping the top, you can take off the front of the machine. There are two screws on the top and then two more on the bottn half of the door. You have to open the door to get these two screws out. There are some wires going to sensors and switches that have to be disconnected.
It is much easier to access the thermostat thru the right side access port.
Aug 23, 2007 | LG DLE0332 Gas Dryer
Dryers Logo
261 people viewed this question
Top Dryers Experts
