Question about Acer AL1914 19" LCD Monitor
Monitor problem, it turn-off in few minutes
When the pc turn on the monitor seems fine but after a few minute the monitor is turn-off but still you can see the desktop if you will use flashlight.
please advise us how to fix it.
thank you
  • Acer Master
  • 5,568 Answers
One of two items has failed; either the fluorescent backlight tube itself or the inverter that produces the high voltage for it. Repair parts shouldn't be over $100 and if you are somewhat careful and don't have 10 thunbs, you might try this yourself. The LCD screen would be a good bit more so you are still in fair shape-
Posted on Jul 27, 2009
    New Friend:
  • 23 Answers
The only thing i can think of is that you either get it repired if still in warranty, or a replacement. Depending what you want, I actually recommend second hand if on a budget, or 1 with a warranty if you have enough
When I turn my computer on it boots up just fine & monitor works. At some point, sometimes a few minutes, sometimes a few hours the monitor will go black and I get a no signal message. The system is...
would appear the system is in standby mode you could disable this
in windows 7 or vista go to
start
control panel
power options
choose when to turn display off
Sep 05, 2011 | Gateway Computers & Internet
Suddenly the screen won't show up. notebook comes on, but no viewable monitor. didn't overheat. battery pack seems fine. fully charged. new. any suggestions?
Look at the top of your keyboard. One of the function keys has one or two icons on it that look like little monitors. Turn on your laptop let it have a fewe minutes to get going then press the "Fn" key at the same time you press that key if it does not work press it again, your screen should come back on one of the times you press them. If it does not then you have worse problems....
Feb 19, 2011 | HEWLETT-PACKARD Hewlett Packard HP...
Display starts out OK, but after a few minutes it begins to flicker in the upper corners, and the turns on and off a few times before staying black?! Everything else seems to function OK.... BIOS issue???...
please check the monitor or LCD that you have. because the computer will not flicker if there is a problem on the display. isolate it. use other monitor or LCD then check if it flickers again.
Jun 27, 2010 | eMachines W4685 PC Desktop
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Samsung 226BW won't turn on until a few minutes.
This is an indication that the power board in the monitor is bad.
Mar 02, 2017 | Samsung 226BW Monitor
Monitor Turns Black
Try reseating the Graphics card first..It may be loose. Or try it in a different slot.
May 21, 2008 | LG Flatron L1715S 17" LCD Monitor
Samsung SENS R65 LAPTOP
look at the screen held in a bright light at an angle do you see the desktop dimly .
if not try the function monitor key,
connect an ext monitor to verify the video card is working ,fn monitor .
if you see the desktop dimly then the inverter may be out or the lamps.
Apr 24, 2008 | HP Pavilion dv6000z Notebook
Monitor shuts off after a few minutes
Can you see the whats on the display but just seems the background lighting is off?
Nov 13, 2007 | Dell Inspiron 1100 Notebook
Makes squealing noice when turned on
make sure that the audio wire connected to the your monitor is fine or try 2 replace it and also makesure that the wire ome the main power which is connected 2 the switch or pc is fine and if necessary replace it i hope it works
Nov 04, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Acer AL1914 19" LCD Monitor Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
