Question about Microsoft Computers & Internet
Hanving a problem downloading the napster. it states i don't have wmp 9 or greater. i jst bought a new laptop with wmp 11. what can i do?
  • 36 Answers
Try to search for the new version of napster
Posted on Aug 21, 2009
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
Samsung YP-U2 & Windows Media 11 on Vista Home Premium
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
Update: Pleasekeep in mind that if you sync your Mp3 player with a computer that hasa Windows Media Player 9 or 10, you should do these steps again
Aug 22, 2008 | Samsung YP-U2X Digital Media Player
Wmp 10 no video
not problem in your wmp 11if download it.....if your pc not genuine..you enter validate.... then install your wmp11 ..ok
hi
r u want other media player install in you pc......just like vlc player.
download it ...now
Apr 01, 2008 | Microsoft Windows XP Professional With...
Samsung Napster YH-920 MP3 Player firmware problem
HI I HAVE THIS UNIT AND IT WORKS FINE ON WMP9 CONNECT TO INTERNET AND DOWNLOAD WMP9[WINDOWS MEDIA PKLAYER 9] FROM MICROSOFT SITE THEN RE INSTALL DISK FOR YH920 BUT NOT NAPSTER SOFTWARE THEN RUN UTILITY FOR DEVICE FIRMWARE REPAIR GOOD LUCK IT DOES WORK
Feb 14, 2008 | Samsung Napster YH-920 MP3 Player
Windows media player can't play .wmv files
  • Firstly a UPS is an abbreviation for Uninterrupted Power Supply - meaning emergency backup power in the event of a mains power failure. This is not a type of PC.
  • Secondly - Windows media player does not support every type of movie format, as Microsoft Update it from time to time, some formats will still not be supported, these are known as codecs.
  • Thirdly, codecs to support your particular format can usually be downloaded and added to Windows Media Player, however i can not think of any reason .wmv files are not supported by Windows Media Player.
You could try re-downloading the latest version of Windows Media Player from one of the links provided below.
WMP 11 will support the latest codecs, but if for some reason you find yourself needing the older version, use WMP 10.
You will most likely have to remove your current version of WMP, and you can do this by using Windows Add/Remove programs.
  1. Click on the Start menu button ( bottom left corner of your screen. )
  2. Click on Control Panel.
  3. Click on Add or Remove Programs.
  4. Click on Windows Media Player in the list.
  5. Click Remove ( right hand side of the listing )
Microsoft WMP 11 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Microsoft WMP 10 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
WMV 11 is available by clicking on this link:
http://filehippo.com/download_windows_media_player/
Feb 05, 2008 | Computers & Internet
Transferring Music from Napster w/o WMP
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downl...
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Sep 01, 2007 | SanDisk Sansa E280 MP3 Player
Computers & Internet Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
