Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
How to install spring
I was in the process of cleaning my Hoover WindTunnel U5753-90, when I lifted up the front wheels the torsion spring popped off and now I have no clue on how to reinstall it. Any help?
  • 97 Answers
On this machine the spring goes to the front wheel assembly under the machine. if this has came off then the wheel assembly is broken. i believe the part # is 36432027. hope this helps
Posted on Jul 29, 2009
My Hoover windtunnel has very little suction. I have cleaned the entire vacuum. Cleaned filters. My Hepa filter is a little torn, don't know if that could be issue. After cleaning it does suck a tad bit...
Is the belt still intact?
Does it has a wand tool, normally they are connected at the bottom of the machine,if it gets plugged up with gunk, that will greatly reduce your suction.
Aug 31, 2013 | Hoover WindTunnel Purely Pet Vacuum...
I have a hoover bagless windtunnel tseries paws. I recently cleaned all the filters & put back together & when I did I thought the red would turn to green like it was reset so wouldnt be showing...
The dirty finder light is a microphone, located in the elbow (where hose secures to machine). The problem is either the contacts on the microphone need to be cleaned (use wire brush) or the switch is full of dust (remove small circuit board from the front (where the light is), with a razor blade carefully pop the cover off the switch box and remove the dust.
Sep 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
How do you install the torsion spring onto the front wheel unit of a Hoover vacuum, model U5760-910? Thanks!
Also,the manual for your vacuum is available online at http://www.hoover.com/CustomerService/Manuals/Default.aspx.
Nov 06, 2010 | Hoover Vacuums
How do I install a hoover windtunnel vacuum cleaner belt. The bagless one,.
First, take it outside or to the basement. This can get messy. Turn the vacuum cleaner upside down. Remove four 1-1/2" self-tapping screws that hold the bottom cover in place (where the beater bar is.) Remove this and you will see where the belts go; one from the beater bar to a grooved wheel and one from a bowed wheel to a metal spindle way in the back. The beater bar will lift right out. Be sure to clean the threads and pet hair while you're at it.
Mar 28, 2010 | Hoover U6630-900 WindTunnel Bagless...
Need instructions to replace hoover U5757-900 belt
install the belt on the motor shaft first by sliding it sideways between the shaft and housing. then install on the brushroll and stretch in place
Mar 06, 2010 | Hoover U5750-900 WindTunnel Bagless...
Height adjustment on Hoover Windtunnel u5755-900 no longer works
On this model it is only a single slide adjustment lever. have you trie to tilt the vac backwards (lifting the wieght off the front wheels) and then slide the adjustment lever?
If there is a mechanical issue with it. take the bottom plate and roller out, and then the 2 small screws which hold the cover on underneath. you should be able to see the problem from there
Jan 10, 2009 | Hoover Vacuums
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover windtunnel Self-propelled - brush roll stops
There is a idler wheel that will drive the V belt, sometimes they jam and you just have to reach in, push and make sure if comes in contact with the belt. Alot of times tho it is the other flat belt, 38528035 that will stretch and can cause you to have problems with the brush roll not turning.
Feb 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
No vacuum suction during normal floor cleaning operation
That door is called a valve door, and it may have broken, part #38718013. Or the valve arm, rear broke, part number 38719048. The spring part # is 38358001. Usually it is the valve arm that breaks. You would have to take the top cover off, then you can see the parts.
Jan 27, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
1,092 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
