Machine is not spinning all the water out.leaving clothes dripping wet when machine goes off
  • pimpandhooke Jul 27, 2009
    No,it does not spin all the water out.It normally leaves 2" or so in there
    Brigadier General:
  • 4,088 Answers
Either the motor belt is loose or worn, or a tub bearing is about to freeze up. Does the pump drain all of the water out?
Posted on Jul 27, 2009
  • drallim Jul 27, 2009
    Look for obstructed drain hose (kinks), debris in pump or blocked drain from tub. Watch the water flow from the drain hose while being pumped out--it should be quite forceful. Ignore the previous advice about loose belt or bad tub bearing.
    Look for an obstruction in the drain system--kinked drain hose, debris in the pump, or blocked drain from the outer tub to the pump. Ignore the previous comments about a loose belt or bad tub bearing.
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
Apr 22, 2016 | Tricity Bendix AW1000W Front Load Washer
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Only spins slow
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 06, 2009 | Washing Machines
Wet clothes after spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
