Question about Whirlpool Washing Machines
I need to replace the lid limit switch. How do I
I need to replace the lid limit switch. How do I get into the body of the machine?
  • jbrown038 Jul 27, 2009
    While I was able to complete the installation without removing the cabinet, I would have never guessed it came off as yo9u show. In the future it will be very helpful.
    Brigadier General:
  • 8,619 Answers
Hi
To replace the Lid Switch first unplug the washer. Then Open the console of the washer. After removing the screws, the console will lift up and hinge back. Disconnect the plug going to the lid switch. Picture. For replacing the lid switch you will need to remove the cabinet. There are only a couple screws holding the lid switch assembly and a ground wire connection to the cabinet. Reassemble the washer and test the operation.
Thanks for using FixYa
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 27, 2009
How do I get my back off my dryer to change my high limit switch?
Some Kenmores are actually Whirlpool products.
1st, Unplug the Dryer from the Power Supply.
Many of the high limit Switches can be accessed by prying the top lid up with a Flat Head Screwdriver at both front corners where the lid meets the body. Once the front anchors are separated from the anchor wells, you should be able to lift the lid from the front as it pivots on the back hinges.
The High Limit Disc should be located in the Rear Center near the top. It is connected to the Dryer by 1 or 2 screws & 2 or 3 wires with Quick Connect Contacts. Make sure you use the exact replacement switch recommended for the Make & Model.
Never attempt to Bypass this Switch as It Will Cause a Fire!
Good Luck!,
Vinnie
Sep 20, 2014 | Kenmore Dryers
How do I remove a lid switch from my washer model #11020432991 part # 3949238?
It's fairly basic. First unplug machine, then you'll have to take off control panel above (the panel that has all the dials or displays) Usually there are screws in the back or you may need a putty knife to slide into each of the two corners to release the clips. Once you get the panel up (don't yank it as it connected with a bunch of wires to the body. Disconnect the electric connection from the panel to the body(should be just one). You should see two metal clips which hold the body onto the frame. Release those two clips and the body should come off as you pull it forward. Now, you can clearly see the lid switch by looking under the body and just unscrew and replace with new switch. Reassemble in same order. By the way, the reason these switch go bad is because people get careless and let the washer lid/door drop down after loading clothes and it weakens then breaks the switch. Happy laundrying!
Jun 24, 2014 | Washing Machines
Why do i have to lift the lid to restart my washing machine
The limit switch that senses that the lid is closed is probably either out of mechanical adjustment or needs replacement due to internal contact wear.
Jul 13, 2012 | Amana Washing Machines
My washing machine has stopped and won't rinse or spin. could it be da lid swictch?
If it's a top load machine there is a good chance that it is , also check to see if the lid on it is not bowed on some top load washers may have the switch in the rear, and can cause that switch not make contact. what you can do is open the lid and look on the right and look for the hole where the lid striker makes contact ,and use a screwdriver or similar object and press in and then put the timer on spin if it works then your lid switch is broken, what happened is that the bracket or body is worn out or broken, replaced it and it will be good as new.
Mar 10, 2011 | Washing Machines
Fills with water but will not spin.
Your problem is probably a bad lid switch NUMBER 11 SHOWN HERE
Flip up the controls to get to the lid switch and replace it
This video shows how to get to that pesky lid switch:
I have a manual and some more videos HERE
Jan 09, 2011 | Roper RAS8244LQ Washer
How do I replace the lid switch?
This is completely dependent on what make and model washer you have. Some washers have a detachable top that is hinged at back and can be released at the front seam with two retaining clips that are gently pried up, or the front panel is removable to gain access to retaining screws at front of machine top. However, many other makes have screwed down tops that are accessible only from the inside of the body, these types generally have bodies that come off the machine in one piece, where they can be turned upside down to access the lid switches. It is very important to know what type you have, so the machine body isn't damaged while trying to access the part. If you have specific make and model number I can tell you exactly how to get to the switch.
Hope this helps
kcomp1863
Jan 01, 2011 | Roper RAS6233KQ Top Load Washer
Machine dont turn on NO Power. Yes I turned the fuse switch on in off for the laundry room no change.
Wit the limited information you have supplied I think your problem is going to be with the lid switch, try bypassing it and see if she fires up...If the washer does fire up make sure to replace the lid switch..it's there for your safety. Hope this helps...if you have any other questions or concerns please feel free to comment again...Good luck!
Jul 08, 2009 | Washing Machines
Need to replace lid switch.
First unplug the washer, then take a putty knife and insert it into the front corners between the top and the body of the washer to pop open the spring clips. Flip the lid up to get to the lid switch. Remove the two screws accessible from the top, pull the two wires off of the old switch and plug them into the new switch, then line up the switch and reinstall the screws. If yo9u found this helpful, please don't forget to rank it.
Apr 20, 2009 | Washing Machines
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Dan Webster
Dan Webster
Sal De
