SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
SOURCE: where to buy a 12V 3.0A output power supply for a TFT monitor
I would just google for power supply 12v 3.0a. However you need to make sure the connector is the same as yours and the polarity is the same. Look for any markings (part number) on your A/C transformer. Search for that first. If no luck then find a similar one.
Here is one such AC/DC power supply:
http://www.smarthome.com/70424/Enforcer-12VDC-3-0A-High-Current-Power-Supply/p.aspx
SOURCE: missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
SOURCE: iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
SOURCE: to low output voltage 4.12 V pdp-121p
you power supply may be faulty or, or you motherboard, even try to update the bois
