SOURCE: logitech quickcam v11.5
Your camera is UVC compliant and can be used with operating systems which fully support this standard; including Mac OS 10.4.9 and above. Please note that standard UVC drivers are provided by the Operating System and will provide minimal camera support only. Unique Logitech features, such as RightLight and Video Effects are not functional via UVC drivers.
SOURCE: Software upgrade 2.0 for ipod touch
Hey Dennis A,
According to information provided by the manufacturer, the "software upgrades" that are included with specific 16GB iPod Touch models are part of Apple's January software upgrade. The upgrade provides e-mail functionality, access to Google maps, weather forecasts, stock market tracking and a notepad program for the iPod Touch.
Apart from this slight change in pre-installed software, there should not be any other difference between the two 16GB iPod Touch models available through your local Best Buy™ store - they have identical hardware specifications.
Please keep in mind that a product's model number may change slightly whenever a minor cosmetic or major software update occurs. In this particular case, the model number MA627LL/A was superseded with model number MA627LL/B to reflect the changes in the factory-installed programs. Both models are considered to be the same generation of hardware.
If you would like more information about this software upgrade, I would strongly suggest checking out the following link:
http://www.apple.com/pr/library/2008/01/15touch.html
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: I have a problem with
In the set-up or menu of the Kenwood there will be an option to enable an "aux" input. After that is enabled you will be able to select it from using the "src" or source button.
SOURCE: cda 9883 and cda 9885 2008 model no song issues
My ipods fuction fine with my Alpine CDA-9885 ... have you tried pressing the display button on the Alpine? The KCE-422i cable takes quite a beating ... You might check the cables.
SOURCE: Problem event PnPDeviceProblemCode The problem
which kind of software do u used? Are driver compatible with ur OS?
May be they are not compatible..
