Question about Garden
I hit a steel water cover and my Toro push mower abruptly stopped. I was unable to re-start. I noticed a fair amount of oil on the underside of the cutting deck and blade. I added some oil and was able to re-start (very noisy) for about 3 seconds and it conked out again. Any Thoughts?
    President:
  • 1,776 Answers
When you hit a solid object with those fast moving mower blades, and you got lucky, it may have only sheared a key in the flywheel. The key is made of soft metal for just this reason...so it will fail before damage is done to the flywheel or crankshaft. Hitting a solid object can bend a crankshaft and cause major problems.
First, the blade and the crankshaft should rotate together. If you feel slippage, the key has broken and will require replacement.
You can possibly avoid removing the flywheel to inspect the key by removing the spark plug and rotating the crankshaft so the piston is at Top Dead Center and noticing the location of the magnet on the flywheel, relative to the position of the pole pieces on the magneto. The magnet should be very close to the magneto poles at TDC.
Hope this helps you and best wishes.
Posted on Jul 27, 2009
  • 636 Answers
Sound like you may have broke the crank casing. Any damage done to the blade?
Mower hit a rock and won't start
On most push mowers, there is a "key" that is located on the end of the crankshaft, opposite end of the blade, that drives the flywheel. It's a small rectangle piece of metal that connects the two. When the inertia of the blade stops abruptly, the flywheel acts as a safety for the engine, and shears the key. Tools are made to remove the flywheel and videos online for repair assistance. Replacement keys are specific to the engine you are working on. Hope this helps!
Jul 24, 2014 | Toro Super Recycler Super Bagger Lawn...
Toro personal pace mower not starting
First check the gas. Old gas after only 3 or 4 months of storage will not fire properly. Completely drain the tank and add some fresh gas. Also take the air cleaner off and check the air filter. It is possible you may have tipped the mower to that side while hosing the grass from the underside. The filter could now be plugged with oil and the motor can not breath. Replace the filter if this is the case. And finally, replace the gasket on the back side of the air cleaner plastic housing that attaches to the carburetor. This gasket if defective or dried out can prevent the primer bulb from injecting gas into the carb when you pump it. Its also possible it fell off if you ever removed this cover which is bolted on with 2 screws. Some dealers even go as far as to put 2 gaskets on to get a good prime. If these simple fixes don't work. You also could have sheared the key way when the motor hit something you ran over in your yard. That will require a shop to pull the flywheel and gets a little more involved.
Jun 03, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
What is wrong with the toro push mower pull cord if it will not pull out?
I would say check the bolts that hold down the pull cord they are the same thread as the cover bolts but the cover bolts are a tad longer and if used on the pull cord housing they stick down to far and hit the fan blades on the magneto and it will not rotate
Mar 11, 2012 | Toro Lawn Mower With Toro Power Tools
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Feb 23, 2011 | Toro Lawnmower Lawn Mower Sp Drive Belt...
Stopped abruptly won't restart
tThe flywheel is indexed to the crankshaft with a soft aluminum "shear" key, when the blade is stopped suddenly the key is broken instead of the crankshaft. The flywheel will need to be removed and a new key installed. Make sure to clean the shaft and flywheel mating surfaces so they fit tightly or the new key won't last too long.
May 27, 2010 | Toro Lawn Mower With Toro Power Tools
We have a brand new toro 22 in Recycler lawn mower that we have used 2x and today it stopped working. We are unable to pull the start cord more than 2 inches out so obviously we cant start it. Help.
Check the oil ... does it have oil in it?
Disconnect the spark plug, tip the mower up, can you move the blade? If the blade will not move, the motor may be seized.
No oil = ruined motor ...
If the blade will move freely, there is a recoil starter problem.
Thanks for your interest in FixYa.com
May 15, 2010 | Toro Lawn Mower With Toro Power Tools
Mower won't start. Toro mower..engine won't turn over. Cleaned sparkplug...checked air filter..weather cool. Followed instructions for cold engine...prime witrh three pushes of the bulb..wnon't even hint...
Something everyone over looks is oil. Did you check the oil? You seemed to mention everything else but. If you have a low oil switch with low oil it will not start
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Unable to restart Toro lawn mower after it backfired and stopped.
Did you hit something? Sounds to me like a flywheel key sheared off or a major internal part broke. My thoughts are you will need to take this to a repair shop or individual that can comfortably tear into the engine.
Oct 24, 2009 | Garden
Clutch seems to be stuck on toro push mower. The cord will only pull up a couple of inches before it stops.
I had the problem of the cord coming out slightly then stop.
The most likely candidate is you are low on oil and the engine seized up. Make sure you have the proper amount of oil. Remove the spark plug, then take a rubber mallot and gently knock the mower blade (counterclockwise) until it starts turning. Continue this process until you can move the mower blade by hand. Once the mower blade turns freely then the cord will be able to be pulled. I found that these Toros use quite a bit of oil especially if you are cutting a large lawn. Check the oil level before each mow to make sure you are not low.
Sep 11, 2009 | Toro Lawn Mower With Toro Power Tools
I have a Toro Model 20072A I am having alot of
have someone push the other side of the axle till you see the groove that the clip goes on to if uou need diaphram go to toro site and look at the schematics it will show you how it goes
Sep 04, 2009 | Garden
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
