Question about Canon PowerShot A510 Digital Camera
Timer Help Hello,I have recently borrowed my dad's camera and I want to set it to take pictures on a timer....but I don't know how to do this. Can you help me?
Re: Timer Help
I was just playing with this myself...
Hit the "FUNC" button and scroll (if necessary) to "Drive Mode"
Scroll right/left to select 10-second, 2-second, or custom timer setting. If custom, hit the "Set" button then select the timer delay and number of shots to take.
Leave the FUNC display on the screen when you hit the shutter release. It begins counting down when you hit the shutter button, so make sure you've got it pointed where you want it (preferably on a tripod, though any stable surface will do in a pinch).
Posted on Nov 27, 2007
0 characters
3 Points
I don't know how to get/find/use the timer on my camera FINEPIX SL245
Press cursor-down (marked with a one-handed clock) to bring up the self-timer menu, use cursor-left/right to select the desired delay, then press the MENU/OK button. Start the self-timer by pressing the shutter release button as usual.
Full details are in the "Using the Self-Timer" section of the manual (page 39 in my copy). If you need a manual you may download a copy here.
Jan 28, 2013 | Digital Cameras
My camera is set to take a timed picture but I don't know what button to push to start the camera timer just before the picture is taken
You declined to specify the make and model of your camera, so I can't be absolutely certain, but on most cameras you start the self-timer by pressing the shutter release button.
If this doesn't do it, please feel free to reply to this post, but be sure sure to specify the make and model of your camera.
Feb 19, 2012 | Digital Cameras
If i put my camra on self timer win i print the pictures will the time show up on the pictures
The time it took the picture? You want to know if the camera will show the time it took the picture using the self timer?
My answer is Yes and No.
Do you have your camera set to showing the date and time on the pictures now? If you do, then using the self timer would not change anything.
If you do have it set to showing on the picture and you don't want the date and time to show then change the setting on the menu function of the camera and turn this option off.
If you do not already have the camera set to show the date and time, using the self timer option is not going to make it suddenly appear.
Mar 26, 2011 | Vivitar ViviCam 5022 Digital Camera
My Nikon D60 self timer is not working
first thing first, you have to ensure that the release mode is set to self timer...
then you can set how long do you need before the camera start to take picture
if the setting above has done, don`t forget to press the shutter button before you let the camera starts its countdown
hope this advice help you with your problem
Nov 12, 2010 | Nikon D60 Digital Camera
Self timer where is it. borrowed this camera for an assignment [ no manual] but I can only deduce from online information that the self timer works in all settings found on the top .. the settings knob
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button.
Sep 30, 2009 | Canon PowerShot A620 Digital Camera
Camera is in japanese or chinese language and we need to change it to english.
go into the setup menu ("set") by pressing the menu button, and look for the picture of a little man yelling (he's speaking). That's the language set-up. Set it for english.
The self-timer is accessed through the arrow dial. The little picture of the clock at the bottom of the dial is the timer setting. The camera must be in the shooting mode to use the timer, not in playback. Here's a link to the owner's manual
May 21, 2009 | Fuji FinePix F10 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Lost book on camera need to know how to set timer to take picture
What camera model is it?
I can help you out but I need to know what camera model. Many cameras set their timer differently.
Jul 20, 2008 | Digital Cameras
There is a long delay taking pictures
Check to see if the self-timer is on. You can set the timer to 0, 2, or 10 sec. A 2 sec. delay will help to prevent blurry pictures. But setting the self-timer to 0 will take the picture as soon as you push the button.
May 26, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Canon PowerShot A510 Digital Camera Logo
55 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
