Question about Samsung LN46A750 45.9 in. HD-Ready LCD TV
I have a samsung hdtv and it shows not supported mode and only sound when i hook up my box to it
  • 585 Answers
HDMI is buggy , lower the resolution to 720 or just use comp cables
Posted on Aug 01, 2009
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Hooking up blue ray to Samsung 1080 DLP
if the tv is not a 1080p model it will not accept a blueray signal and the optical output from the tv only works thru its own tuner not with the inputs or cable boxes
Jan 31, 2010 | Samsung HLN617W 61" Rear Projection HDTV
No video output
for the ps3 i know why u are not gettin any video. make sure the ps3 is off with the red light showeing in the front then hold down the power button for (i think) 30 sec. u will see the light blink a bunch of times them you might have to re start it but it should show the vedeo againg
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
I have 19inch samsung lcd tv i use an hdmi cable to connect my x box to it but it shows up mode not supported is it my lead thats not working are my tv
Try this HDMI input with other HDMI source such as DVD, Blueray or from cable box. If it does not work as well, you need to replace mainboard.
Aug 08, 2009 | Samsung LN46A530 46 in. LCD HDTV
Gray box on screen with sound.
It sounds like you need to turn off the text mode in the closed captioning menu,
Jul 23, 2009 | Samsung HLT6187SAX 61" DLP HDTV
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Jul 02, 2009 | Samsung HLN5065W 50" Rear Projection...
"Not Supported Mode" Message...
Your tv does NOT support any higher than 720p res.
Is your cable box set to this? If not, and it is set to 1080i than it would explain this, and is also a common problem with computer(vga) connections even with monitors. To see the current resolution the box is set to hook up a yellow jack to the to from cable box just to get the picture back long enough to navigate to a setup menu and lower the resolution back to the highest supported which is 720p
Nov 04, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Samsung LN46A750 45.9 in. HD-Ready LCD TV Logo
106 people viewed this question
Henry  Thomas
Henry Thomas
