Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
I have LG-12AW2 Dishwasher, it starts for 20 seconds and it stops and the light flashing and for about 10 minute later it gives a code IE what that mean and how to fix it
  • 1 more comment
  • Pepetheskunk Jul 27, 2009
    i have lg dishwasher it given me a code 1e or ie or le please explain
    i have already checket all that and they working fine what else could be the problem
  • Pepetheskunk Aug 07, 2009
    i told you i was not saeisfied wiyh the answere you give me i have called my local repairer they came and told me it was the motherboard. and now i want you to refund the money that you took out from my creditcard thank you.
    Brigadier General:
  • 8,619 Answers
Hi
The code IE means its a Water inlet trouble. You need to check clogging of water inlet hose (or hose twist or freezing) and also check water supply. If there is clogging you need to clean it so that the issue is resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 27, 2009
  • Rylee Smith
    Rylee Smith Jul 27, 2009
    Hi
    First measure the electric resistance of the Inlet Valve. If it’s between 950-1300 ω, then it means the valve is fine, if not you have to replace the Inlet Valve. Also is there any water coming in? If yes - could be flow meter. If no - could be water safety shut off valve or connecting wires. If you could check for voltage at the Water Valve when it should be filling.
    Try disconnecting the Water Valve outlet from the Dishwasher and run the output into a bucket. Remove the door panel and inspect the wires near the bottom of the door. The wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.
    Thanks
    Rylee
  • 3,037 Answers
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Breaker
Let me know how this turns out.
Benjamin
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
My LG dishwasher, model LD-12AW2 runs for 10 - 15 mintues and then goes into a H and flashing 'E' fault. This fault isn't listed in the manual.
Happy to be of some help. Please keep this list around so you can take notes if the problem comes back.
Good Luck!
Apr 13, 2009 | LG Dishwashers
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG ld-14aw2 dishwasher
Possible cause:
Remedy:
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Ie problem on lg dishwasher
The IE is telling you it is not getting enough water. Could be your water pressure is low. Check to make sure the there is not a build up of grime, or calcium deposits in the water hose, and at the valve.
The other thing is if your unit is an older one, prior to mar 07, you may have broken wires in the door. Remove the door panel and look for any wires that are stuck in the insulation. The sensor wires are thin and gray in colour. Splice the wires and put some of the white insulation in between the wires and the door so it cannot happen again.
Broken wires can be hard to find if the break is not all the way through.
Sgt Lauder
May 11, 2008 | LG LDF6810 Built-in Dishwasher
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
241 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
