Question about Cameras
My memory card is in the camera Sony DSC f828, however it said on the screen NoCFcard and what does that mean?
  • 2 more comments
  • mbrady472 Jul 27, 2009
    It is the same problem and I did format the memory chip. What else can it be?
    Same problem!!!
    same problem
    On the screen on my camera Sony DSC-F828, it said NoCFcard and I was told by the FIXYA expert to format the memory chip and try again, well it not solving the problem. What else can it be?
  • 453 Answers
Insert the Microdrive /CF card.
Set the CF switch and record the image using the memory stick.
I was not able to insert image in the above message. So kindly check the below link.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=DSCF828revisionpdf&sliceId=pdfPage_130&docTypeID=DT_MANUAL_1_1&dialogID=115852333&stateId=1 0 46188141
Please check page 130 for the information on the error message.
Kindly comment.
Posted on Jul 27, 2009
  • Cameras Master
  • 6,487 Answers
You need to format the memory card first before using it , if you cannot format it using the camera menu you can format it by using a card reader and format it via the computer, but if still the same problem better if you have a different memory to test with it because this can be a problem with the card...
The camera shoes that the memory stick an the card are FULL when they are empty..
Format the memory stick,right click it in my computer and left click once the format tab.
Mar 19, 2011 | Opteka (OP-T5XUHD-F828) for Sony DSC-F828...
My DSC f828 sony camera's lens is loose. Sony says it is not worth repairing. Surely there must be a way to fix this ? thanks
I'm not sure what you mean by "loose". Does it still take good pictures? If not, then Sony is correct...the camera was introduced in 2003 and the cost of repair would far exceed the camera's worth.
Oct 01, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Where can I find a memory card with more megabites of memory?
The sony cyber-Shot Dsc F828 does not work well with memory stick that are more than 2gb. I have used 4gb memory stick, but realised that it failed to record most of my photos. Other are recorded but hard to extract. I would recomed 1gb stick. Keep more than one
Nov 15, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
Cyber-shot DSC-F828 memory stick error C:13:01
HI,
Please clean the gold contacts of your memory card.Take any lead pencil. Take the eraser and rub it on the gold contacts on the memory stick as if you are erasing writing on paper. Do this for about 30 seconds or more until you get all the gold contacts. Put the stick in the camera, switch to 'Setup', then turn the camera on. The 'C:13:01' error will automatically disappear. At this point, quickly format the memory stick using the camera's format feature.NOTE:
Al;ways use the camera's built in function to format your memory card.Do not use the computer to format the memory card.
If you still face any problems then you will have to get it repaired.
Thank you
Sep 11, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
DSC-F828 Son a camera whatpage in the manuel
Go to setup menu and select Format (memory stick) press OK. That will delete all picture files on memory stick in one click.
Aug 24, 2009 | Sony Cameras
What is the maximum memory C/F for sony DSC-F828
On the Sony website it says 4G is the maximum "capatible" size. However from my understanding about the description, 4G is the file size limit on the FAT32 format, the camera should be able to use 8G card. Puls 8G cards often provide higher speed. If you wanna be safe, use 4G, if capacity is an issue, use 8G
Jan 22, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony DSC F828 - getting C:13:01 error message.
The Sony DSC F828 service manual states that this is because the media is either damaged or not formatted. It is suggested to format it inside the camera with the camera's format utility.
There are a few memory sticks that have not been tested (certified) with this camera and will not work correctly. Also it is possible to get a damaged memory stick that is readable by a computer, but the camera will not read it.
It is best to format it with the built in utility
Dec 09, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
