Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Overheat issue on kdf-50we655 sony tv
They had a overheat issue on sony tv they fixed it twice changed lamp door, changed sensor that caused problim....anyways tv doesnt come on light flashes8,9,10 times then red lamp light flashes.thats a new lamp, I think going to tell sony going to file LEMON LAW, or new tv.this expensive tv
Http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Posted on Aug 23, 2009
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Jan 27, 2015 | Sony Replacement lamp for Grand WEGA or...
My Sony 3LCD tv picture and sound goes on and off, what's wrong?
How old is your TV have you replaced the lamp already this lamps are made to last a avarge of
2-4 years of use if you have not replaced the lamp before that would be the first thing to do but if you already replaced the lamp recently and have this issue then it will be a BALLAST issue
I found the lamp you need just incase
http://www.discount-merchant.com/SearchResults.asp?Search=KDF-50WE655
PLASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!
Oct 13, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
We Have a Sony KDF-50WE655, we've replaced the lamp and housing and we still have no picture or sound. Can you help?
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check.
If still no picture or sound then check power/standby light is blinking?
If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem.
Thanks.
Aug 01, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
How can i open my sony KDF-50WE655 TV to change the lamp?
hello go to this website www.instructables.com this will show how to change your lamp good luck
regards
shaun
Jan 15, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony KDF-50WE655 that shuts the screen off after 3-4 minutes , the front light flashes green for a minute or so and then turns back on for 3-4 minutes. Is it over heating? How easy is it to fix?
Chances are is the Lamp is bad. Call 1800-222-SONY and they can get you one ordered.
It is a very common thing to happen particularly if you have not replaced the lamp before. Average hour life of the lamp is 3000 hrs.
Hope this helps,
Skyassoc
Jul 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
SONY WEGA KDF-50WE655
Did you replace your lamp with a generic lamp? Many generic lamps do not produce as much light as OEM lamps do. Also, you may have a separate issue causing the picture to appear less clear than before. Check my solutions to other Sony LCD owners who have had problems with their optical blocks( light engines)
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wega kdf-50we655 went off and thier is a buzzing noise
Anything that sounds like electrical crackling will be coming from either the lamp or lamp driver/ballast boards or their interconnections. The lamp should be examined first as this is the most likely cause.
michtech
Feb 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lamp on the kdf-50we655
Hi, very common to do that, nothing to worry about, video-tek
Feb 10, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kdf-50we655 dim picture and turns off and then back on
Symptoms shows that Tv requires new Lamp.
Lamp replacement procedure is written in user manual. Let me know if you need further info about Lamp purchase or need user manual.
Please buy original Sony lamp for replacement.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
359 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
