Question about Canon PowerShot A470 Digital Camera
Camera not staying on LCD display message.
My batteries went dead while the camera was on and now with the batteries recharged when I tun it on it displays please restart camera. I have only had this camera since March 2009. When I turn it off and then on again the lens move and then began to act as if it is jammed. It keeps making a beeping noise.
  • 724 Answers
Remove the batteries and externally recharge them . Sometime batteries , in some cases can have a polarity change but then the camera may just not turn on.
Posted on Jul 27, 2009
My batteries went dead and camera shut off. Now I
if the camera wont turn on remove the memory card and make sure your pictures are transfered. Try using regular disposable batteries. Also when trying to turn it on try holding down the power button for 5 seconds. If it still doesnt turn on coud be a broken switch connection.
May 14, 2010 | Canon PowerShot A540 Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Are you getting any power from it? How about an error message?
Try blowing some compressed air into the battery chamber. There might be some debri or dust in there. Try replacing the battery to see if that solves it. (Someone you know must own a D70).
Apr 20, 2009 | Nikon D70s Digital Camera
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
No Power
did you make sure you have a memory card in the camera, i know with mine it wont power up unless there is a card in it.
Jun 17, 2008 | Fuji FinePix S5000 Digital Camera
Wont stay on
You probably don't have the batteries fully charged up. Also you will need to change battery type from alkaline to metal hydride in the "wrench2"(the last icon on the menu) menu. You did get metal hydride rechargeable batteries??? If you got nickel-cadmium rechargeables that might also be your problem with your camera as they don't have enough power.
Aug 28, 2007 | Samsung Digimax S630 Digital Camera
P73 switching off!
This is most likely a weak battery. Be sure to charge at least 14 hours before using rechargeable batteries. If alkaline, replace with fresh ones. The zoom motor uses more power that any other features.
Nov 23, 2006 | Sony Cyber-Shot DSC-P73 Digital Camera
I can't take a picture with the camera. What's wrong?
The batteries may be low. If you see the low battery icon, recharge or replace the batteries or use the optional AC adapter. The flash may be recharging. Wait until the status light turns green, and try again. The camera may be full. Check the picture counter on the display panel. Erase some pictures, or transfer the pictures to your computer and then erase them. Make sure your CompactFlash memory card is installed. You may need to format your CompactFlash memory card. Check to see if a message is displayed on the camera's LCD screen. The camera may be connected to your computer. When it's connected, you can't use any of the controls on the camera itself. See your user's manual for instructions on taking pictures from your computer.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Canon PowerShot A470 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
