Question about Frigidaire FMV156DC Microwave Oven
Microwave is scratched
I am buying a new home and the microwave is very scratched where  they tried to clean it. How can i buff that out?
    Problem Solver:
  • 5 Answers
You will need the following:
Polishing compound, jeweler's rouge or whitening toothpaste
Electric buffer
Lamb's wool buffing pad
2 ounces of ammonia
2 quarts of water
Rubber gloves
Safety goggles
Lint-free paper towels or cloth
Step 1:
Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
Step 2:
Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
Step 3:
Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
Step 4:
Clean the glass surface with the ammonia water with a clean soft sponge.
Step 5:
Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to replace or rebuff the glass.
Posted on Sep 12, 2009
Scratched Control Panel
Normally yes, however you must contact to the supplier manufacturer and ask them because some material are compatible other NOT.
Get the support via ONLINE char or phone.
God bless you
Sep 30, 2012 | Frigidaire FGMV185KF Stainless Steel...
Panasonic Microwave NNA883 cuts out after 20 seconds.
You need to replace the diode. Scratch that. The voltage let alone the radiation could kill you. Call a technician. If it is a table top unit, buy a new one. It will be cheaper,
Aug 27, 2012 | Misc - MFG Microwave Ovens
Door error message on microwave whirlpool Gold rmc275pd
This indicates the door is not latching. The simplest fix is if it really isn't closed, and simply pressing on the door does the trick. Not so lucky? Latch mechanism itself may be dirty and not latching. Try cleaning it with standard spray kitchen cleaners and a good scrub, followed by a toweldry. Still no good? There's often an electronic interlock-- a place outside the latch, perhaps along the face of door, which must contact the body of the microwave oven. Again, try cleaning all possible contact areas. No? OK: microwaves are designed not to run without a tight seal to prevent emissions. perhaps the seal itself is damaged. Finally, and most unhappily, and expensively, the electronics module in the combo unit is shot. If the appliance is under warranty you're in like flynn; if it's relatively new but not under warranty, call the Whirlpool service 800 number and very politely but firmly remind them that this is really quite a new unit and certainly their products aren't meant to fail so soon... and surely they have a service bulletin because this can't have just happened to you... This will usually result in (oh happy day!) a free service call or (more common) a deal to sell the part at half price. Better than nothing!
Jul 03, 2012 | Whirlpool RMC275PD Microwave Oven
I need a new door inner glass for Panasonic NN-A772SBBPQ microwave/combination oven
Think about calling up the Sears 800-4MY-HOME line... the parts dept can look up your model with the LIS and have the part sent to your address and a Tech to install it for you if you don't know how, plus if you do pay for a tech repair for like $40 they do a clean and prevenative maitnence check on any other appliance you may have thats acting weird.
Mar 07, 2012 | Panasonic Microwave Ovens
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
HELLO.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
Thanks.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave was heating up some coffee I stopped it and opened the door and it went completely dead. Nothing at all works. Should i try and fix or do I need to buy another microwave?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;';;';'
Sep 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Boiled water and it exploded, now the microwave is broken
wow, from the looks of it you need to unplug wait 60 seconds plug in to restart, ot buy a new microwave. Perhaps if in the microwave terms it didn't say not to do that call the manufacturer and the will replace it for free
Jul 03, 2009 | Maytag MMV5000 Microwave Oven
Front of microwave door scratched
3M 7447 pads get at auto parts store or more aggressive 180 grit sandpaper going with the grain of course. For daily cleaning use DeBruce Polish, it is non-toxic and odorless. DeBruce polish is also non-abrasive, also use DeBruce Polish on glass/ceramic cook tops. We get DeBruce Polish at debrucepolish.com
Feb 27, 2009 | Frigidaire FMV156DC Microwave Oven
Scratches on microwave door
We have an over the range GE microwave and my wife was cooking some pasta on the stove and used the vent fan on the microwave to dissipate the steam and when we were done eating she noticed that the steam from the pasta had gotten in between the glass on the microwave door, how can we get rid of this any ideas.
Jan 07, 2008 | Viking DMOR205SS Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
301 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
