SOURCE: when i shift into third the gears grind.. why?
sounds like the syncromesh has gone in the gearbox. If you dont want them to grind, you,ll have to double declutch. I f you cant do this, get a new gearbox.
SOURCE: Engine gets to a high RPM before it shifts
check all vacuum starting at the pump on these mpodels and see if you are getting around 29" of vacuum. if you are not this is your issue. it sounds like it is doing it mechanically and not assisted. this is a very good way to destroy your transmission. it is very possible that you have a leak somewhere else in the system causing a vacuum leak. i am guessing all your door locks do not work.email me at [email protected]
SOURCE: my 1991 toyota pickup does not go into third gear
remove your shifter and check the plastic bushing at the bottom tip of it. Replace if worn, if ok it may be a trans problem!!
SOURCE: My 1993 toyota pickup won't go into gear.
there is still air in the system, keep pumping it will eventually come out. if it has a bleeder try that
