Question about The Computers & Internet
How do we write an agreement letter for lobola to be legalized at Home Affairs?
The grooms family want to lobola in customary /traditional marriage, therefore both families wish to hand over the agreement letter of lobola to Home Affairs to be registered. Please help us. Give us the sample of those letters.
    Top Expert:
  • The Master
  • 84,619 Answers
SORRY BUT - You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use
Posted on Jul 10, 2017
SOURCE:
  • 186 Answers
SOURCE: Won't print out legal size paper
some machines have a setting on the tray as well as in the menu. I would check both.
Posted on Jun 21, 2007
SOURCE: nokia 6630 Sim Card locked......Kindly help unlock.....
if u put the lock code in wrong about 5 times it should ask u for puk code you can get this code from your service provider ring them up they ll give u the code over the phone this ll override the security code and then reset it to 00000 so get the code wrong a few times then call the service provider when ur phone asks for the puk codeits 11 digit and it from ur service provider
Posted on May 10, 2008
SOURCE: won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Posted on Jan 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: how to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
SOURCE: second hand archos 605 already registered can I re register??
ask the original owner to de register the product
Posted on Feb 20, 2009
What can i do if landlord refuses to fix broken sewer line to septic tank and everyone in the home is getting sick. Raw sewage has been under the home for better than 9 mos
There's a governing body that regulates rental agreements. Contact them and notify the department of the issue and have an inspector come to the property to assess the issue. The landlord will eventually be served a court order to repair the problem. There are also health department and building codes that will more than likely affect your situation. You have legal rights and obligations as well so if you need to notify the land owner of a third body entering the house, do so. Make sure you follow your responsibilities on the rental agreement to the letter so you are protected legally.
Sep 15, 2018 | Cars & Trucks
Writng a letter stating the details of my marriage and the lenth feeling abanded not sure how to state it?
1.You must get someone who can write English correctly.
2.Give all the details and explain what you want written in the letter.
3.If this is for legal reasons find a good family solicitor.
May 14, 2017 | Miscellaneous
How can i get my marriage certificate from home affairs
we have no idea why you would have given it to them .
Feb 08, 2017 | Computers & Internet
Helps with heart problems
DOCTOR-LOST LOVE SPELL CASTER, SOUTH AFRICA SANGOMA- TRADITIONAL HEALER-LOST LOVE SPELL CASTER, WESTERN CAPE PSYCHIC &TRADITIONAL HEALER LOST LOVE SPELL CASTER , INTERNATIONAL HEALER-LOST LOVE SPELL CASTER, ASTROLOGER& HERBALIST HEALER TRADITIONAL HEALER, +27737951814 TRADITIONAL DOCTOR VOODOO SPELLS ASTROLOGY HERBALIST HEALER, WESTERN CAPE TRADITIONAL HEALER-PSYCHIC HERBALIST HEALER, SPIRITUAL HEALER {INTERNATIONAL} SPIRITUAL LOST LOVE SPELL CASTER IN JOHANNESBURG, ALEXANDER, LENASIA, MIDRAND, ROODEPOORT, SANDTON,SOWETO, MSHONGO, ALBERTON, GERMISTORN, BENONI, BOKSBURG, BRAKPAN, CLAYVIEW, DAVEYTON, DEVON, DUKUZA, ADENVALLEY, MPUMELELO, ISANDO, KATLEH,EAST LONDON,PORT ELIZABETH,WITBANK,MPUMALANGA, RUSTENBURG,MAFIKENG/DURBAN,AMERICa,botswana,ghana,namibia,mozabique,uk london Relationship problem solution/husband wife problem solution/get back lost lover •Work related problems/get promoted at your work/win work hearing •Win bonds/Tenders/contracts/loans within 12 hours •Criminal matters/legal matters/courtcases/divorce cases •Lottery wins/ lotto/horses/soccer big wins/ all gambling activites •Body cleansing/property cleansing/ business cleansing. •Business promotion/sales promotion/ customer attraction. •Unfinished jobs by other doctors/ Delayed jobs/ failed jobs. •Magic ring/ magic wallet/ magic stick for wealth and marriage. •Spells for getting married to the lover of your life. •Spells for love, victory and sympathy. •Fix broken marriage, relationships and finding a missing person. •Spells for getting job/employment/higher pay/job protection. •Spells for loan repayment/debts and financial problems. •Expert in destroying effects of black magic/evil
Jan 10, 2016 | Heating & Cooling
How can I change my marriage status?
What do you mean by change your marriage status??? Do you want to actually change it by getting a divorce or etc or do you just want to change it from single to married or married to single etc on records somewhere???
Sep 21, 2014 | Computers & Internet
Computers & Internet Logo
263 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Fred Sops
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
