Computer display is too big for screen
I connected my computer to my lcd tv and it worked fine until one day i turnedthe tv on and the display was too big for the tv. i could not see the start button at all and my top icons was half way off the screen as well. i reset the computer settings and it didnt work i hook the computer to a reg monitor and it was fine. i hooked another computer to the tv and it did the same thing. can anyone help me?
  • Travis
    Travis May 11, 2010
    Were the settings you changed the resolution settings?
    Novelist:
  • 85 Answers
You need to turn off OVERSCAN in your computer display controls. This will reduce the picture size by 5 to 10% and allow access to the edges. Expect there may be an edge around the screen with nothing in it. Overscan was introduce in TVs to use the whole tube. It is not needed in digital displays. -Ken
Posted on Jul 27, 2009
I have an LG model #60PK750 serial #010RMWV8M569, the other day I was watching and the screen went black and no sound, I did get a display on the screen that said lost signal.
Fixya is a free tech support site. There is mo shop. No replacement parts.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 07, 2015 | LG Televison & Video
Why is desktop green like theres way to much yellow hue
- Flickering screen
- Dim screen
- Slow start
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
How do I center the display on my LCD
Adjust the display resolution via the contrl panel until you find the one which best suits your TV
Aug 19, 2009 | Computers & Internet
Signal is not compatible with this input when i connect my laptop
If the screen resolution on your laptop is to high or not supported by the TV, that is the usual error message.  I'm not sure what video output you are using but if it's the common S-video output, high resolutions will not be supported through it so maybe try a lower resolution and work your way up until you get the message again.  Then you will know the threshold.
Mar 26, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
COMPUTER WON'T WORK WITH NEW HD LCD TV
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Dec 19, 2008 | Computers & Internet
Using windows media XP warning comes up on screen-NO INPUT. Why?
update your video card driver or adjust your screen resolution and color bit
Dec 05, 2008 | Computers & Internet
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
May 20, 2008 | Televison & Video
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Televison & Video Logo
1,209 people viewed this question
Top Televison & Video Experts
