Question about Audio Technica ATW-T52 Professional Microphone
How do I program the frequency of transmission on the mic?
  • 71 Answers
Some of these have a body cover that just unscrews off, and expose a set of rotary channel and group selector that you can turn with a small flat screw driver. Match to the new numbers letters on the receiver. If it is the LED type you just need to hold the ch or grp button down until the display flashes then just toggle through the codes.
Posted on Jul 27, 2009
No transmissions on Uniden Bearcat BC80XLT
Are you sure the frequencys have not changed in your area? They changed in mine recently. uou can do a search about your area freqs. Make sure antenna is in all the way, easy things, etc. here is a link to the manual if you need it. www.racingelectronics.com/files/bc80manual.pdf
Jan 19, 2015 | Uniden Radio Communications
Puxing px 777
I would check the mic hole in the face of the PMR_2 to verify if there is anything covering it IE. tape stickers debris wax paint anything of the like. Also if the radios are digital, they may use a DPL code. If you have the computer program to set the frequencies and associated programming cables, connect them to a computer with that same program and verify the frequency output they need to be the same frequency. Also, they may use a DPL code ( channel encryption code that keeps channels private on a common frequency) if so they need to be the same. If they are analog then you check the frequency and the TPL code if it has one. All codes/ frequencies must match for communication to happen between the radios.
Jan 25, 2014 | Radio Communications
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
I have a uniden 355n scanner how do i program it?
Hi Janice,
First of all, you need a list of frequencies that you wish to program into your scanner see:www.radioreference.com.
Once you've got a hard copy of your favourite local frequencies, you will need to program them into your scanner.
Example only!!!
123.7000
This is an air band frequency but only for example this is what you need to do.
Press prog key, enter the frequency exactly as I have typed them here: 123.7000, press delay key, press L/O key only if L/O is showing on the display, now press Enter key, you now have the first frequency programmed.
Now press Hold/Mon key and you will be given the next channel to program, follow the steps above until you have completed the setup.
When complete, press scan and every time the scanner detects a transmission, it will stop scanning during the transmission, prior to scan again.
You can stop scanning at any time by pressing the Mon/Hold key, when you hear a transmission that interests you. That way you won't miss anything interesting.
I hope this helps you in your hobby.
Cheers,
Peter
Feb 17, 2013 | Uniden Radio Communications
My yamaha did not come with the optomizer mic
You can, and the results might be better than not optimizing, but they might be worse.
The optimizing process listens for resonant frequencies in the room (what pitch "rings" longer in your room) as well as damped frequencies (what pitch sounds "dead" in your room)
To do this, it needs a mic that's matched to the unit.
Different mics have different frequency response curves, so your friend's mic might think (for example) that 2500hz is really hot, but the yamaha mic would think it's normal.
Certainly won't hurt to try, but if you don't like the way things sound after optimizing, then just reset your yamaha to the default EQ.
Sep 16, 2009 | Yamaha YSP-800 System
All 4 mics wil transmitt through channel a,
Sounds like all of your mics are using the same frequency. What you can do is change crystals in each unit to change frequencies, this will allow each mic to use its own receiver.
Mar 31, 2009 | Pyle Music
Maxon SL25
if the band assigned to the radio doesn't cover the frequencies you want then it will not happen. you need to get the software and the right programming lead. make sure the mic socket is good and clean
Nov 19, 2008 | Honeywell Maxon SL25 Two-Way Radio Battery...
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
Loss of bass frequencies in dynamic mics
That's one correct assumption, but it's actually the element that gets damages causing the coil to rub. Open the top up and see if there is any damage, sung a magnifying glass as the tiniest crack could go un-noticed by the naked eye.
In testing these 2 did you change the frequency at all? trying with a different receiver, having another mic on the "bad" mics frequency?
Loss of lows can also be a sign of a bad wire as this sometimes tend to act as a high pass filter.
Did you do the obvious, change batteries?
jeff
Dec 22, 2007 | AKG D8000S Professional Microphone
Audio Technica ATW-T52 Professional Microphone Logo
431 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
