I cant find the drain pan! - Heating & Cooling
  • 534 Answers
Find your evaporator coil (the one inside the house in the furnance) this coil sits inside of the drain pain for the reason to drain condensating water. Good Luck
Dave
Posted on Jul 27, 2009
I am changing tranny filter and fluid on my 2003 kia sedona,it is the canister type filter,will it drain all the old fluid when i remove the old filter and where is it located.
cant see a drain plug on the pan in this diagram
you may have to get a pan gasket and filter
undo the pan to drain all the fluid out
Nov 25, 2016 | Kia Cars & Trucks
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Cant find the drain plug on the oil pan for my 1999 chrysler concorde lxi
The oil drain plug is located on the side of the oil pan, passenger side. It does not look like a typical drain plug, as it's one of those quick drain type. It is meant to be hand loosened and tightened. DO NOT OVER TIGHTEN or you are in for a world of hurt. Just firmly finger tight
Sep 04, 2012 | 1999 Chrysler Concorde
Where is transmission filter located in 2001 mitsubishi diamante located and how do i change it?
transmission filter in the bottom of transmission bolted to valve body.you need a large drain pan.place drain plug under transmission oil pan.remove transmission oil pan drain plug.let all transmission fluid drain out then screw back drain plug in oil pan.then you need to remove transmission oil pan then remove filter and replace pan gasket also.make sure you have right amount transmission fluid on hand.buy extra because if you short of fluid you cant drive car if fluid level too low.make sure you get the right amount fluid.torque pan bolts to 96 inch pounds.
Nov 10, 2011 | 2001 Mitsubishi Diamante
How do you remove the transmission drain pan on a 2003 Chevy S-10 ZR5? All of the bolts are removed, but we cant get the pan off to drain and clean the pan??
Once you have removed the bolts, sometimes you have to take a thin flat object and insert it inbetween the pan and the transmission as the adhesive used to seal the pan gasket will hinder the removal of the pan itself. Hope that helps.
Jan 21, 2011 | 2003 Chevrolet S-10
I cant find the oil drain plug where is it
the oil drain plug for your oil pan is on the bottom of the oil pan sometimes its on the back side of the pan.
Jan 14, 2011 | 1998 GMC Sierra
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
SANYO MODEL STWO923H1 CANT FIND THE PAN DRAIN
find the drain outlet and use a wet vac to extracate the water from the pan Slime has appearently clogged the drainage tube Good Luck
Dave
Oct 02, 2009 | Heating & Cooling
Locating Ruud Central Air drain pan?? Water has started dripping through the ceiling from the Ruud Central Air Unit...can't find drain pan?
the drain pan is physically inside the indoor unit.
grab a 1/4" nutdriver and open the bottom service panel your coil and drain pan is there, you won't be able to remove the coil properly but you could see if the system is overflowing causing your flooding problem, let me know what you find
Jun 22, 2009 | Heating & Cooling
Cant find drain for tranny on a 91ford probe
you have to remove the trans pan as there is no drain plug
Jun 15, 2009 | 1991 Ford Probe
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
