Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
THE BIT DOESNT STAY IN PLACE
THE BIT FALLS OUT NO MATTER WHAT
  • 2,176 Answers
Could be 2 problems, first are you using the right type of bit to lock in this tool and second the ball that locks into the detent of the bit might be stuck or the ring holding it in has moved. Give me a brand and model number and I will find a breakdown for this and see if I can give you more help
Posted on Jul 27, 2009
  • gtimberlake Apr 17, 2011
    PD600 Type 2 Black & Decker Plus cordless drill - can't get drill bit out - have read several possible solutions but none have helped so far. Any other ideas?
Driver window manual want stay on track and falls down
your window has fallen off its track. either remove the inner door paneling and re seat it on the track, or take to mechanic. It is a cheap repair.
Nov 11, 2015 | 1985 Ford F150
Ac blows out the defrost vents. It doesnt matter wich setting it is on
there might be something down the vent , it used to happen to ,a pen or something left on the dash falls down the vent and jamb it open.
Oct 22, 2013 | 2005 Nissan Titan
Bit falls out of impact driver
There is a small spring at the back of the sleve which snaps. Try replacing it. it is only cheap.
Feb 02, 2013 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
Th race will not stay in place
it's possible that the race may be damaged & needs to be replaced
Mar 14, 2012 | Singer 3116 Simple
The arm won't stay in place. It is loose and falls down.
Try to fix its' screw tight. I don't know whether it is the problem or not. also you can take it to a computer repair store and fix it.
electronics wholesale
Dec 16, 2011 | Jabra GN9125 Wireless Headset
The bobbin holder falls out when I try to sew
What brand and model of sewing machine? May be able to find a graphic and instructions you can view.
Feb 21, 2010 | Sewing Machines
The bit in my Stanley ratchet screwdriver does not lock into place, falls out when screwdriver is pointing down
There is a small springs steel wire that fits into the chuck. the bit slides into the chuck and then into the spring and the spring holds the bit inside the chuck. This ring seems to be missing. Thus the bit falls out. You might try going to a hardware store and they make a device that is two magnets held together with a rubber band. When they are together there is a small hole in the center. You can slide any screwdriver or bit into the hole in the center and it magnetizes the bit or driver. Magnetizing your bits should keep them from falling out of the ratchet screwdriver.
Dec 04, 2009 | Tools & Hardware - Others
Push the accelerator, nothing happens or falls on face and dies
you might have a vacuum leak just get a can of carb cleaner the spray kind not the foam stuff and spray it around your carb and vacuum lines and see if anything changes.l
May 21, 2009 | 1987 Volkswagen Jetta
I installed the Pioneer AVIC-F900BT and it has been
Windows CE is used to operate the Pioneer AVIC F series, which yours falls into. That version of Windows has not been patched or updated with the new day light savings times and since the player uses GPS to get the current time and Windows to make the time change for your zone then your time will not update until the orginal daylight savings time occurs. You can try to change the time to manual in the Pioneer settings, deal with the wrong time for just a lil bit longer until the original Daylight Savings Time takes place, or re-search an update and way to update the players OS which is Windows CE. Hope this helps :)
Mar 10, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Memory card doesnt stay in my blackjack!!!
The blackjack micro SD card goes in gold pins facing up,
you must push it past the edge of the phone for the lock to
engage, use a car key to push the card all the way in.
and the same to remove the card.
Jun 27, 2008 | Samsung Blackjack SGH-I607 Smartphone
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
372 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
