Question about Car Audio & Video
Hay can you please tell me the colors for the speaker wires. Like L/F color and all the others thanks
  • 30 Answers
Usually black is ground and red is considered hot. But in general, polarity does not matter on a speaker so switching up the wires won't ruin anything.
Posted on Jul 27, 2009
Need a wiring diagram for a DEH-X6600BT. IT'S GOING IN A 1993 CHEVY ASTRO VAN. I KNOW KNOW THE WIRES OF THE VAN. I NEED TO KNOW WHAT TO CONNECT TO ON THE RADIO. THAY ARE DIFFERENT COLORS.
I hope someone comes along who can help; in the meantime, you might try the following. Naturally the power wires will be 12V and usually red(+) and black(-), if they're not, you can examine the other colors, to determine if their are separate ground wires for each speaker. If it uses a remote, and you want to hook that up; I can't help. sorry. But, if the speakers have a common ground, there will only be 1 wire for each speaker, the other connects to the ground of the car. If there are two wires for each speaker, they will be 4 different colors, with a 2nd wire which has the same color for all 4 speakers, so each speaker has a colored wire, and a common colored wire. This will leave the power connections, unless you have other controllers (see above).
One you know which are the power wires, you can connect them to a spare 12 V battery, and then comes the fun part. While adjusting the radio for front back, left and right, using the colored and a common wire for each speaker, this will be the same as the ground wire for the power even if not the same color, you can connect it to ground for the test. Then connect the colored wire and common wire to a speaker, by adjusting the controls you can find out if that colored wire is for front or back, left or right. Then you'll have your color code.
Although prolonged use of only one speaker or only two could cause damage to the radio, short use to troubleshoot at low volume shouldn't be an issue. Just don't use it that way.for a long time!
I hope this helps. Let me know.by rating up my answer! :-)
Sep 03, 2015 | Cars & Trucks
Igntion wire colors
IT IS BEST TO EITHER VISIT LIBRARY OR GET A HAYES/CHILTON BOOK THAT COVERS YOUR CAR THEN YOU WILL HAVE COMPLETE WIRE SCEMATICS AND KNOW WHAT COLOR AND ITS USE
Mar 09, 2014 | 1998 Chevrolet Cavalier
Car Stereo Speaker Wiring Colors for a 2001 toyota Solara
Radio Battery Constant 12v+ Wire: Blue/Yellow
Radio Accessory Switched 12v+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Stereo Antenna Trigger Wire: Black/Red
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 17, 2013 | Toyota Cars & Trucks
I cant remember how to hook up the speakers to the system
Speakers use a cable that consist of 2 insulated wires. The two wires are identified by one or more ways: 1) one wire may be golden colored and the other white or silver colored, 2) the insulation on one of the wires may have a raised ridge, or 3) the insulation on one wire may have some marking along the surface where the other will not
The terminals on speakers and terminals for the speakers on the amplifier will both have a (-) and (+) symbol for each cable (one for each wire). I like to assign the (+) terminal to the golden colored wire or the insulation with the rib or marking on it, and the (-) terminal to the white or silver colored wire or on the smooth or unmarked insulation. It does not matter which wire you assign to which terminal - as long as the (+) and (-) terminals of the speaker connects to the (+) and (-) terminals on the speakers of the amplifier (you should see to it that they do not get crossed so that the (+) of the speaker is connected to (-) terminal for the speakers on the amplifier).
Connect each speaker location to the corresponding speaker terminal on the amplifier (the front right speaker to connect to the front right speaker terminals on the amplifier - continue until all speakers are connected). Failure to connect correctly will make fading front to back and balance left and right work unexpectedly.
I hope this helps and good luck! Please rate my reply. Thank you.
Apr 09, 2011 | Audio Players & Recorders
I do not know what the color codes are for my 2005 ford 250 super duty radio.im trying to change the radio .please contact me when you find wat the colors mean thank you
Dont cut the wires that will be very bad.You need the color coded plug it may cost more than others but you need that bestbuy.com or crutchfield.com
Mar 20, 2011 | Car Audio & Video
I have a geo prism 1994 i need to know all the possibilty colors for the specker wires! i would really glad if you told me! thank you
YOU NEED A HAYNES REPAIR MANUAL.YOU CAN BUY ONE AT ANY AUTO PARTS STORES. SPEAKER WIRES COULD BE MANY COLORS LIKE LT BLU - DK BLU -YEL - BRN - DK GRN - LT GRN - GRY - TAN.THE HAYNES MANUAL WILL TELL YOU WHAT WIRE COLORS FOR EACH SPEAKER.
Sep 18, 2010 | 1994 Geo Prizm
Someone cut the front door speaker wires and dont know the polarity or color codes please help 2000 ford mustang convertable
One wire should be a solid color and is the + wire to the speaker connection, the other wire should be a two colored wire, but will have a small color stripe running along the length, this is the - side connection.
Mar 13, 2010 | Car Audio & Video
I'M trying to install a cd player in my 1994 chevy caprice but I dont know which color wires are the factory speaker wires or memory can you please tell me what color wires go to what ? Please Thank You
take a multy meter put it on 12v check the powr from the eart to all the outher cables norm it would be yellow red black test the on of from the ignition
Nov 01, 2009 | Alpine CDA-9851 CD Player
I need the color codes for rear speakers in a 1996 thunderbird lx.
positive wire is red, yellow wire is positive on ignition okey for the speakers remember the solid color like green green w/ black line is negative follow the other coding w the solid colors
Apr 12, 2008 | Pioneer DEH-P6800MP CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
