2000 Volkswagen Jetta TDI Logo
Posted on Jul 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why after charging the battery in a 2000 vw jetta this wont start
Why after charging the battery in a 2000 vw jetta vr6 glx model the car wont start?
  • Jonah Oneal Sep 07, 2013
    sound like battery dead.
    check battery volts should be 12.6 volts.
Jonah Oneal
Level 3:
  • Volkswagen Master 14,092 Answers
  • Posted on Jul 27, 2009
Jonah Oneal
Volkswagen Master
Level 3:
Answers
14092
Questions
0
Helped
7240647
Points
44533
SORRY TO TELL YOU WHEN DISCONNECT BATTERY ON VOLKSWAGONS.YOU MUST USE A MEMORY SAVER.IN CIGARETTE LIGHTER.TO KEEP COMPUTER MEMORY.IF YOU DONT.YOU HAVE TO GET A SPECIAL SCANNER TO REPROGRAM CAR LIKE THE DEALERSHIP.
My 2002 VW Jetta VR6 GLX 2.8 DOC is giving me a P1151 code. I am trying to see what will cause the problem?
Fuel Air sensor is the most likely cause, but can be other things.
P1151 Error Code ' VW Vortex - Volkswagen Forum
https://www.vwvortex.com > ... > Golf IV & Jetta IV
Aug 6, 2014 - Can't pass my emissions inspection with my check engine light on. Code is P1151. Possible causes: MAF Sensor, O2 Sensor, Vacuum leak.
Missing: DOC ‎' Must include: DOC
pm151: i hve 2003 jeta VR6..engine light..fuel air - JustAnswer
https://www.justanswer.com > ... > Volkswagen Questions
Sept 11, 2009 - I have 2003 Jetta VR6 and the engine light is on and have a code reading of P1151 fuel air managing how can I trouble - Answered by a ...
1 answer · 17559/P1151/004433 - Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Lean The ECM is trying to compensate for an excessively lean mixture. ...
2001 Jetta GLS VR6 CEL Code P1151 ' VW Forum
https://www.vwforum.com > ... > MK4
Jul 5, 2009 - error code P1151 "bank1,Long Term Fuel Trim, Range 1 leanness Lower Limit Exceeded". Explanation - fuel pressure or volume. Probable cause
Missing: 2.8 ‎DOC
p1151 code My 2001 vw jetta glx vr6 has a p1151 code. What
https://www.fixya.com > ... > Volkswagen
Nov 16, 2019 - p1151 code My 2001 vw jetta glx vr6 has a p1151 code. What is the problem I need to fix? - Volkswagen Cars & Trucks question.
I m geting an engine alarm and the code is P1151 . - Fixya
Nov 19, 2019
2003 Jetta GLI throwing P1151 Indicating a lean condition
Sept 2, 2019
SOLVED: I need the Serpentine belt diagram for a 2009 - Fixya
Apr 17, 2021
I need torque specs 14B coaster bus.cyl head and - Fixya
Apr 14, 2017
More results from www.fixya.com Missing: DOC ‎' Must include: DOC
2001 Jetta GLS VR6 CEL Code P1151 - Volkswagen Forum
https://volkswagenforum.com > forum > 2001-jetta-gls-...
error code P1151 "bank1,Long Term Fuel Trim, Range 1 leanness Lower Limit Exceeded". Explanation - fuel pressure or volume. Probable cause. Check engine for ...
Missing: GLX ‎2.8 ‎DOC
P1151 code and white smoke on idle - The VR6 Owners Club
https://www.vr6oc.com > ... > Newbies Corner
Mar 14, 2020 - Hi, i just recently bought a 2002 vw jetta vr6 24v with 123000 miles on it. Car runs good and sounds healthy but just here recently ive been ...
2answers
Engine car code P1624 lights up
P1624MIL Request Signal Active, Probable cause = Trouble code(s) stored in other system(s). call dealer to find out more info. Good-day!
I have a 2000 vw jetta glx with the vr6 that needs the timing chain replaced there is an upper and lower one. So I was hoping at minimum that someone could post a link to a complete walkthrough along with...
The Jetta vr6 has a timing chain. These don't have to be replaced unless the gear is worn. When worn they will jump timing by a tooth or two. This will cause the engine to run rough. Is link http://forums.vwvortex.com/showthread.php?1264409-DIY-Replacing-timing-chains-tensioners-and-guides-on-a-12v-VR6 10_10_2013_3_02_45_am.png
1996 volkswagen jetta glx vr6
I am sorry but these manuls are not free to share as they are copyrighted by VW.
5helpful
2answers
Ignition coil firing order for 2000 VW Jetta VR6
Jetta GL & Jetta GLS (two versions with 2.0 l and 115 CV engine)
2000 Volkswagen 2.0 liter SOHC L4 (AEG)
Jetta GLS VR6 y Jetta GLX VR6 (2.8 l VR6 and 200 CV engine)
2000 Volkswagen 2.8 liter DOHC V-6 (ATQ)
Hope helps.
My transmission on my 1995 vw jetta lll glx vr6
the clutch may burn out on those gear, check the fluid if it smell burn
1helpful
Jetta vr6 timing
need timing for vw jetta 2000 vr6
14helpful
3answers
2000 VW Jetta VR6 My check engine light started flashing. My car was idleing very rough and missing. The parts store checked and the code showed misfire 1. We replaced the spark plugs. It runs a little...
You may have a bad coil pack - try moving two of them around and see if the misfire follows the coil pack or stays at the same cylinder. If it follows the coil pack, get a new one. If it stays in the same cylinder, inspect your spark plug wires and make sure the plug is gapped correctly.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
