Question about Waterway 1 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing # S10115
Pump does not pump water
When I turn on my spa, the pump hums but does not pump water. Is the pump toast?
    Master:
  • 430 Answers
Also most pumps have a one way check valve that keeps the water at the pump level.. if I I worn out water will run away from the pump and it will get no water to push... on a big pump for the well it is called from foo valve and is located at the end of of line inside the well on a smaller pump it should be close to where the water enters th line... unless it is submersible which means the pump is under water.. also look to see if t filter is clear.
Posted on May 19, 2016
    New Friend:
Could be the capacitor blown.
Posted on Dec 30, 2012
  • 10,865 Answers
Hi there. Not necessarily. Inside the pump the impellor is plastic. Sometines the fins deteriorate to the point where the pump hums but won't move water. Other times the pump hums but won't actually run. The pump is generally fixable. If you are handy you can remove the pump and take it to any pump repair shop to be reconditioned, usually for about $50-75.
Posted on Jul 27, 2009
I have an in ground fibreglass saltwater pool and the water will filter will not pump.
a humming noise is a frequency noise meaning the motor is not running
check / replace the start/run capacitor for the pump motor
call an electrician for a proper diagnosis
Dec 28, 2016 | Pool & Spa
Motor hums but won't kick on
motor high limits tripping defective motor replace motor or whole pump
Jun 14, 2014 | Pentair 1 HP Challenger Pump
Pool pump motor does not turn pump when timer trips
does it hum at all.. turn the impeller with a small rod se if it will sart up..
Dec 31, 2013 | Intex Wet Set Water Filtration Filter Pump...
Pump runs but humms
Question:
What do I do if my pool/spa pump is humming and has low flow?
Answer: by Osko Pool n Spa Pool/Spa Pump Humming and No Flow If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system.
2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 15, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
Pump hums
hums as in it did not turn on and pump water or hums like it should be running great?
Rod
US Parts Center
888-521-6183
May 28, 2012 | Jacuzzi Pool & Spa
Pump hums
prime the pump.Put some water in it
May 20, 2010 | Polaris Pb4 - 60 Booster Pump
My Mustang pool motor by Waterway musts-120 is just humming when it is turned on. It is connected to a timer, but the pump is working fine, just the motor is humming. What do I do? Is my motor toast?
Check your loacl yellow pages for an electric motor repair shop. They may find it is fixable but could at least tell you if it is salvagable or not. Some even carry replacement motors at costs lower than the pool stores.
Jun 10, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Waterway 1 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing # S10115 Logo
1,212 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Craig Butler
Craig Butler
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
