Question about Dometic RM2193 Compact Refrigerator With Ice Box
Just bought a tent trailer with a Dometic Fridge.
Just bought a used tent trailer with a Dometic Fridge. Fridge cooled yesterday on AC. Went camping, could not get gas to light and DC would not work. Now fridge will not even cool on AC. Where do we start with the troubleshooting?
  • pawandnanny Oct 05, 2010
    My refrig ac want work but the gas will work on the refrig
    President:
  • 704 Answers
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Posted on Jul 30, 2009
I have a dometic frig in rv rm2611 on a/c or gas it wont get cold when i listen to it it sounds like water is running thru it could this be freon low brenda421@verizon.net
Posted on Nov 25, 2009
    Problem Solver:
  • 6 Answers
Sounds like the gas mixture has seperated
try:tip fridge upside down 6 hours ,on left side 6 hours right side 6 hours ,leave upright for 6 hours and plug it in
If gas wont light clean gas jet and purge air from gas lines
Posted on Jul 27, 2009
  • cge6 Jul 27, 2009
    sounds like the gas mixture has seperated
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Refridgertor is not cooling dometic rm2804
If the fridge is level and the rear coils of the cooling unit get warm and the fridge does not cool then you require a replacement cooling unit. Yours has leaked. Contact ArctiCold Refrigeration We keep it cold Online store: http://www.rvfridgerepair.com/ 60f363ae-5e9d-402e-98c8-b8fed71c2461.jpg
Jun 23, 2013 | Dometic Refrigerators
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
My fridge is in a pop up tent trailer and exausts out the side. It works fine on electicity but not at all on propane? It is lit and gets hot on the coils, just doesnt cool the fridge. Thanks
Believe it or not those fridges have to be perfectly level to operate on gas. Make sure of this on both axis. Front to rear and left to right.
Aug 21, 2009 | Dometic RM2652 Refrigerator
Dometic fridge. cooling it while traveling
If the trailer have good shocks absorbers, is posible traver with the unit on 12volts conection.
Aug 11, 2009 | Refrigerators
Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Jul 06, 2009 | Dometic NDR 1292 Refrigerator
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
New Travel trailer......no fridge!
Unit should still be covered on warranty call dometic directly. The tilting could affect some. If you push the auto button in it should run on electric first if no electric present it then goes to gas. Exception to the rule is if the heating element is not working it does not recognize this so it will stay on electric. Unplug the 110v in the compartment on the outside it should change to gas with in a few seconds. If it does heating element is bad.
Aug 18, 2007 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2193 Compact Refrigerator With Ice Box Logo
1,682 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
