Question about Hitachi 51S715 51 in. Rear Projection HDTV-Ready Television
Hitachi 51s715 color went bad
Hitachi 51s715 - color suddenly goes bad. It appears to have a green or yellow haze. If I turn the tv off and then back on, the color is normal for a while. The time before it goes bad varies.
  • 375 Answers
SOURCE: Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Posted on Apr 13, 2008
SOURCE: blue haze/cloud in center of screen, slowly spreading
how to fix my problem Blue haze/cloud in center of screen, slowly spreading .but last time my lamp broken I order by my self and fixed now I have the blue color in my screen please let me know what is the problem may be I need to replaced same parts please let me know how to fix thank you
Posted on Jan 07, 2010
Ecollier2012
  • 3459 Answers
SOURCE: 54inch Hitachi TV has double figures and colors
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 14, 2010
Testimonial: "Very Helpful. I'll check this out and return to this site and notify. "
SOURCE: I have a Hitachi 55VS69A television. I replaced
I have a Hitachi Ultravision. 55VS69A. It has worked wonders but now there is a blue screen in the center of the tv. Should I just replace the bulb. thank you.
alex
Posted on Apr 28, 2010
SOURCE: My Hitachi 52 inch Projection TV video goes one
hitachi 52' tv...the blue color is off...you can put magic focus on and it still want move the blue back where it needs to be
Posted on May 10, 2010
Can i connect a regular dvd player to a hitachi flatscreen hdtv?
Yes you can. Simply connect the appropriate color inputs.
If you use red green blue for video, and red white for audio you will get the best picture
If not stick to yellow for video and white red for audio
Just remember color that is on the back of dvd goes to same color on the input for the tv
Mar 21, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Model 51S715: 2 issues: (1) Screen is bowed at top...left and right edges turn down and are black. (2) picture color will turn green randomly. If I turn tv off and leave off for a while the color goes...
Ur tv have a problem call convergence,it dying about to be dead.The tv convergence board 2 STK Convergence ICS and some or all it resistors require changing to solved the covergence problems.U have tools,soldering iron,solders and know how to do soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Sep 10, 2009 | Hitachi 51F500 51" Rear Projection...
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Color out of line
Sounds like a convergence problem. First, try using your set's user convergence mode.
Mar 25, 2008 | Hitachi 46UX24B/25K 46" Rear Projection...
Hitachi 50" big screen TV
You have a defective light engine and Hitachi is aware of it. Here's what you need to do...recently went through this. Call Hitachis customer relations department at 800-654-7013 and tell them you have a defective light engine. At first, they will act like they've not heard of this problem but they are all too familiar with it. They will give you the names of some certified dealers in your area. Once the tech comes out and confirms the problem, call Hitachi back at the 800 # I listed and they will call and confirm with the dealer that you have a bad light engine. They will send a brand new light engine to the dealer (Hitachi will cover the cost $1500) and the dealer will call you to come out and install.
Here's the kicker, if you're not still under warranty, Hitachi will cover the expensive part but you will have to pay the install. Our install was $400 but others on this site have paid around $200. If you're still under warranty, Hitachi will cover the part and install.
Please do not let any dealer tell you that you have to pay for this part. Hitachi has not recalled this part but they are replacing it to you for free...you just pay the install. Also, deal only with their customer relations at the 800# I listed.Good Luck:)
Feb 12, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 60 in. 60V715 Yellow Haze
I would first check and see if any software updates are out on this set, you can call Hitachi, if not that then it could be the engine assemble having problems.
Jan 02, 2008 | Televison & Video
Blue screen
I would look for something real simple here. The problem appears to be in your component cables (I would suspect one being bad or connected to a wrong jack). If they are connected properly, try moving them a bit to see if the blue haze comes and goes or try different cables.
Dec 28, 2006 | Hitachi 43GX01B 43" Rear Projection...
Hitachi 51S715 51 in. Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
