Question about HP Pavilion dv1000 Notebook
My dv1000 is not charging. The volt meter is showing that the charging devise is working.
  • 724 Answers
Sounds to me that the batteries are not seeing the charger or the battery system is bad
Posted on Jul 26, 2009
Just switched on my meter and it is showing 16.66 is this a flat battery
That number is too high even for a battery that is being charged. A fully charged battery with the engine OFF should read 12.6 volts. With the engine running it should NOT be higher than 14.7 volts. The meter should be set to DC volts. The picture below shows the symbol for DC volts and the correct setting for the multimeter when testing batteries.
Jan 25, 2018 | Cars & Trucks
Yamaha 450 Kodiak battery not charging, new battery, volt meter not showing any voltage going to the battery
Hi Brian, get a digital volt meter and start the ATV measure the voltage at the battery or at the alternator it should read around 14 volts when charging, if it reads 12 volts the charging system is not working, check or a blown fuse or broken wire, if you can access the alternator directly measure at that point. It takes 14 volt output from the alternator to charge a 12 volt battery
May 06, 2017 | Yamaha 2005 Kodiak 450 Auto 4x4
Do not get 24 volts from 120/24 volt transformer how test it?
Yes. There could be a couple of high limit safety devises in the circuit that can open the circuit to the gas valve. Pending your furnace type If your thermostat is calling for heat and the furnace tries to start your transformer is working. High limit safety controls are normally closed. If you have a open limit switch you will not have any continuity through it using an ohm meter or if you test it with a volt meter you will have 24 volts across the terminals of the safety devise. Other problems can be pressure switches, hot surface igniters and control boards. most newer furnaces have a control board that will flash a light code to help trouble shoot the system. Count the flash pattern and look on one of the furnace doors for the flash code directory.
Jan 01, 2015 | Heating & Cooling
How to do BSI reset on Peugeot 206
A meter will show a charge from an alternator but what charge was it . IF it is not 14.5 volts and DC volts not ac volts then the alternator is not working properly and that is why the light is staying on. Best have the electrics checked out at an accredited auto electrician shop.
Aug 24, 2014 | Peugeot 206 Cars & Trucks
How can i know if my voltage regulator is working, Im not getting any of my lights to work
quick check is to remove a battery cable while the motor's running. If the motor stays running when you pull off the battery cable, the charging system is functioning properly, if it dies then there is a problem with the charging system. Don't leave it off long, as this test is stressful to the circuit. You can test the voltage regulator by putting a volt meter across the battery posts to verify voltage. A fully charged 12 Volt battery should show slightly above 12 volts DC. With the engine running and the volt meter hooked to the battery, the charging system should be showing around 13.8 volts DC.
Dec 02, 2012 | Cars & Trucks
Battery discharges in about 3 days if not run.
it may have deffective diode on the charging system(the alternator). 14 volts is an over charge in a battery. ampere reading must be on what the battery designed.
Mar 01, 2012 | 1997 Jeep Grand Cherokee
Hello i have a 1990 harley davidson softail custom,i've own it for 20 years,i don't think its charging,battery is fairly new when its running and i remove the ground cable it stops dies out i put a test...
Marshall:
First, your battery MUST be fully charged to perform these test. You'll need a good DVOM (digital volt ohm meter) but an analog meter will work. Connect the meter across the battery with the read lead to the positive post and the black meter lead to the negative post. Put the meter's function switch in DC VOLTS, 20 VOLT range. Start the engine and bring it to a high idle. Your meter should show a slow build up of voltage over about a thirty second period of time. It should read 14.5-15.0 volts.
If not, you'll need to test the alternator. Unplug the regulator at the front of the engine. Look inside the connector in the engine case and you'll see two metal connectors. Put one meter lead into each contact. It makes no difference which lead goes to what connector because we're checking AC voltage. Now, set your meter function switch to AC VOLTS, 50 VOLT RANGE. Start the engine and bring it to high idle. You should read at least 30 volts.
If you read 30 volts or more at the alternator but less than 14 volts at the battery, replace the regulator. Naturally, less than 30 volts at the alternator, replace the stator.
Good Luck
Steve
Oct 14, 2010 | Harley Davidson FLSTC - FLSTCI Heritage...
Charging problem 2000 roadking
Good Luck
Steve
Oct 13, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
1994 olds cutlass supreme volt gauge shows low I have a new battery and a new altenator could the both battery and altenator put out correct volts no drain on battery even change dash volt meter still in...
check with a volt meter if u have 12 volt at the big lead on the back of the alternator engine off
if thats good start engine check to see if alternator is charging check the battery a good alterntor charges 13.5 - 14 volts, u may have a bunk alternator
Mar 25, 2010 | 1994 Oldsmobile Cutlass Ciera
Battery won't charge
sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Mar 22, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
