Building Materials Logo
Wanda Beddo Posted on Jul 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My genie garage dooropener is blinking red on the opener motor. It is suppose to be blue.
Jerome
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 06, 2022
Jerome
Contributor
Level 1:
Answers
Questions
0
Helped
24017
Points
My Gene 7055's red light has a continuous red light. The door will open and close when I reset the + and - but then the red light stay on and will not open with the wall or remote
Rich Brown
Level 2:
Scholar:
  • Expert 106 Answers
  • Posted on Jul 10, 2017
Rich Brown
Expert
Level 2:
Scholar:
Answers
106
Questions
0
Helped
70953
Points
291
1. If both round and long LED's are blinking, unplug the opener motor for five seconds, and replug. If the lights go back to normal, it was just a program error. If they both continue to blink, it's probably not user-serviceable.
2. If the round LED is blinking and the long LED is off, it is usually the door sensors that are obstructed or knocked out of line.
3. If the Long LED is blinking and the round LED is off, it is usually a bad roller or hinge that won't let the door move freely, something stuck in a track or a bent track.
1helpful
On my Genie garage door opener, do the sensors have to line up for the red and green sensor lights to come on
You did not list the model number and that would have been better but, there may be a problem with the sending unit on the sensor, the receiver or the power to them from the opener motor unit. You can test for sender failure if they are UV by using your camera phone and look for a purple light coming from it, you can test for output using a voltmeter
Genie 7055 opener long and round lights show green then quickly blink red every two seconds.
contact genie, you may have a defective unit. If you just bought unit remove repackage and return for another one.
Have a genie belt driven opener and won't close. 1 and it stops. Electric eyes are clear. Red light blinking on motor. Help??
try holding down the wall switch while trying to close. if this works and the door closes, then you have misaligned sensors, loose wires on the sensors or a broken sensor wire.
1helpful
How do I program a "clicker" brand remote for a genie pro 83 garage door opener?
generally you find the program button on the motor housing, press it once and it should start blinking, then press the remote button, and then press the remote button again and see if it works.
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Genie garage door opener wont do anything. I just bought it today
Press learn on the ceiling mounted opener point the remote at the opener then press open three times then a light should blink test by pressing open if this does not work you should take it back to where you got it then ask for a refund
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Programming my keyless entry
Yes, you purchased the wrong wireless. You must get a Genie keyless and there are two types of Genie keyless (GWKP & GWK-BL) depending on which Genie operator you have. You might think about a wired keyless entry (Domino GD-1). Then if you change your operator you don't have to change your keyless.
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
