Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet 1440
Amp light comes on when pto is turned on. Put in new battery,same light comes on.
blueextc3221
  • 15935 Answers
SOURCE: A short in the pto wiring perhaps?
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
highspeedsan
  • 61 Answers
SOURCE: cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Posted on Apr 25, 2009
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
  • 109 Answers
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Posted on Jun 03, 2009
  • 59 Answers
SOURCE: cub cadet z54 will no start
one of the safety switches are bad it could be the seat are the clutch are the blade switch you can try jumping a wire to the posts after you unplug them one at a time
Posted on Jun 26, 2009
Everything works fine until I engage the PTO for the mower deck. The battery discharge light comes on and eventually the battery goes dead.
The PTO clutch is an electro magnet. There is probably a dead short within the clutch body. Replace the Clutch.
Aug 26, 2015 | Cub Cadet Garden
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet riding mowe
is the mower making any sounds when u crank it or nothing at all?
Feb 07, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
When I engage the PTO clutch, the amp light comes on my 1641 cub cadet. I have new battery, pto clutch and stator. I can mow for awhile, but when I turn the PTO clutch off, I can't engage it again because...
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Nov 07, 2009 | Garden
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet mower pto will not stay engaged while cutting? has new belt any suggestions
Apr 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
398 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
