Question about White Sewing Superlock 2000 ATS Mechanical Sewing Machine
My hand wheel on my serger is super tight and is barely turning, and basically the machine is not working?
  • 55 Answers
Your machine needs servicing. make sure you oil all spots indicated in your user manual and turn handwhel by hand for a minute or so to work oil in.
if this doesn't make machine easy to turn see a tech for full service.
scott
Posted on Jul 26, 2009
I bought a used white serger model 523, the hand wheel won't turn?
Since it is a White, am assuming it is a mechanical machine. If so, most likely it has languished without use or TLC and over time, the oil has turned to glue and then varnish. When this happens, it actually freezes the moving parts--a very common problem with older machines. Sergers actually require more frequent cleaning and oiling than sewing machines.
If you are mechanically minded, you can try carefully removing the case. (Remember how it came apart!) Then while gently rocking the handwheel and using fresh, good quality serger oil or Tri-Flow Synthetic Oil, apply only a couple drops every place that metal parts rub metal parts. Avoid oiling synthetic parts and belts. The machine may even have built-in oil ports, but applying directly to the joints and knuckles will also work although not quite as efficiently. Avoid soaking it with oil and be sure to wipe off any excess. Then direct heated air from a handheld hairdryer into the interior of the machine. This may take multiple repetitions to get it loosened.
Or you can take it to a repair shop.
Sep 22, 2016 | Sewing Machines
Riccar serger hand wheel stiff
Could very well be seizing due to lack of oil or buildup of lint, etc. Sergers generally require frequent oiling with fresh good quality oil (consult the manual). Continuing to force the motor to run when the machine is seized can burn up the motor.
Sep 10, 2016 | Riccar Sewing Machines
Hand wheel turns half way and won't go any further,nothing appears to be hitting anything
Did you do a thorough oiing "inside" the machine--like take the bottom or back off, hand rotate the handwheel and apply a drop of "fresh, good quality serger oil" every place where metal rubs against metal?
Jun 11, 2017 | Sewing Machines
Blocked motor message for 2140. Has happened 3 different times. Sewing machine repair is two hours away and I need my machine today. I did all the thread things suggested with the bobbin, re threading,...
You said the hand wheel barely moves. Is that all the time? If the hand wheel is hard to turn the motor is getting overloaded and is protecting itself by stopping and giving you the error message. You need to determine why the hand wheel is tight. There could be thread caught or something might need lube. These are non oiling needed machines however sometimes a linkage might need fresh lube.
Sep 12, 2013 | PfaFF Sewing Machines
Stiff serger
Sounds like a tired motor, or a belt that is too tight. Take it in for service. Sergers are way too complicated for the average home user to repair.
Mar 14, 2013 | Sewing Machines
Necchi serger pl1036 hand wheel screw keeps falling out
Try some removable thread locker on the screw. Then retime.
Sep 13, 2012 | Necchi Sewing Machines
Brother 1034d serger needles go up and not down
if a part has come loose or broken then the machine is not going to respond, it needs to be serviced
Mar 14, 2012 | Brother 1034D Mechanical Sewing Machine
Loud thumping noise
Usually means a needle, knife or looper is bent and everything is out of alignment. Try all new needles and replace knife, then carefully hand-rotate your wheel and watch the alignment as everything stitches in super-slow motion. If you can see the bent part, you MAY be able to gently bend it back in alignment, but because these are such precision machines. it will probably need a service, which is good anyway because the technician can clean and oil the machine very well. It's worth it to have it serviced. Remember when you hear a knocking next time, to stop immediately and investigate.
Sep 08, 2017 | Baby Lock Eclipse Serger
Needle centering wheel is stuck tight and cannot
On these machines, the shaft UNDER the centering wheel fits into a bushing, and this is what normally rotates. The wheel is fixed to the shaft. Penetrating oil needs to be placed UNDER the centering wheel but above the bushing. We solved this problem on two machines by saturating dental floss (the kind used to clean braces) with penetrating oil. Insert the floss UNDER the plastic wheel around the shaft, with the two ends sticking out the slot for the centering wheel. Then cycle the floss in and out of the area around the shaft. Let it soak and repeat. It takes some time, but it worked, and did not require disassembly of the machine. Greased Lightning also was used. Kithen grippers help with rotating the wheel.
May 07, 2009 | Sewing Machines
Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Sep 16, 2008 | Bernina Bernette 75
White Sewing Superlock 2000 ATS Mechanical Sewing Machine Logo
170 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
