Question about Brother Sewing Machines
Thread tangles in bobbin really bad, can't solveproblem
  • 55 Answers
Make sure machine is threade as manual indicates. make sure presser foot is up when threading.
once threaded, lower presser foot and pull needle thread, it should cause needle to bend a little as thread comes through needle. if needle does not bend, tighten needle tension after checking thread is between tension discs and there is no foreign matter caught in tension discs.
scott.
Posted on Jul 26, 2009
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Kenmore 158 12271
the bobbin case is not located properly. take it out check the bobbin fits fully inside it.
Feb 18, 2014 | Sewing Machines
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
Bobbin thread is tangling around bobbin carriage as I sew. So I can only go a few stitches before the machine stops sewing and it's tangled.
Hello
This is Really not that big a problem. Simply pull out the bobbin thread with a long lead, put the assembled bobbin into the sewingmachine and take that long thread and close it between the sliding door and the machine itself to hold it temporarly.
Most sewing machine problems are caused by the usasge of wrong thread type. Make sure you have a thread that is for a sewing machine use, that is, good strong stuff, not hand needle basting thread as that will cause much problems.
Often the bobbin is thought to be the problem, those things are almost never the problem. A source of problems also is the usage of wrong or improperly machined flat on the needle itself. Be sure to buy a quality needle as that flat on there, if machined not deep enough will not allow the bobbin to pick up the thread, wind it around and form the stitch.
Jul 12, 2011 | Singer 4830
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
How do i put threed into the bobbin and keep it from not getting tangled?
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Sep 29, 2010 | Singer 1507
The bottom thread is all tangled. I have
Hi! This is the machine I use (mostly) and I've found it really doesn't like lint. I brush out lint every few hours and it has made a huge difference in how my machine sews. I suspect your machine may be as sensitive to lint as my is, so give her a really good cleaning. Then, rethread (yes, I know you've done that already, but do it again, for grins.) everything. Pay careful attention to the way the bobbin thread comes off the bobbin (from left to right) when you rethread. If you usually use the automatic bobbin pickup, don't. Pick up the bobbin thread the regular way, and, holding the top thread and bobbin thread securely in your left hand, start to sew.
I sure hope this helps!
Please let me know if this works, ok?
Robbie
Jan 28, 2010 | Brother CS-8060 Computerized Sewing...
Burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Jul 16, 2009 | Bernina Bernette 75
Needle Thread and Bobbin Thread
This is a timing problem and will have to be repaired by authorized dealer.
Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
Sewing Machines Logo
119 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
