Question about Garden
MY HUSQVARNA 136 CHAINSAW WILL NOT IDLE DOWN. IT RUNS AT HIGH SPEED AT START UP. IT CAN BE SPED UP BY PRESSING THE THROTTLE BUY IT WILL NOT IDLE DOWN.
    Scholar:
  • 173 Answers
This sounds like a sticky throttle cable.
Check that it's route is un-inhibited.
Though, the cable itself may be freyed, and thus in need of replacing.Happy and safe chopping:)
Posted on Jul 27, 2009
Husqvarna 55 chainsaw has a problem running on idle
start by checking all ur fuel lines for holes then proceed to clean or rebuild ur carb the ethonal in fuel is cloging small engine carb jets and making needles stick so then adjust ur carb back to factory settings try with new air filter as well and run 89octane or higher in your two stroke motors u will c a great differance in performance
Dec 13, 2012 | Husqvarna Chain Saw Models 51, 55
I have a 450 X torq and it runs at high speed and wont idle down dealer told me it wasnt in the adjustment that is probably a seal on the crank. Has anyone had this problem
The dealer could well be correct, if a two stroke engine has an air leak through a seal or gasket, it will draw air through here and not through the carb, this in turn will weaken off the mixture and cause high running at idle, there are other reasons, like the throttle flap is not closing properley, or the throttle cable is not correctly seated, remove the top cover and turn the throttle shaft manually to the idle position.
Oct 13, 2012 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 51 idle seems to struggle, runs OK when I throttle then chokes and dies out as soon as the throttle is released. What can I do?
will it start right back up after it dies? you could use a small screwdriver and turn the idle screw in a little to raise the idle speed that should fix it.
Oct 09, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
Husqvarna 136 chainsaw
Both H and L screws should be set 1-1/2 turns out from stop. Turn the idle speed screw two turns in from where it is now. When you had the carburetor apart, did the rubber diaphragm seem hard? If it did, re-kit the unit. When you clean the carburetor body, use spray carburetor cleaner and use compressed air to blow out all fuel passages including the two mixture control screw holes. Be sure to check the condition of the fuel line and the air cleaner. Even a plugged muffler can cause weird problems.
Aug 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can't set carb. on Husqvarna chainsaw.
Most chainsaws and small engines are 1.5 turns out.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 20, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Husky 350 chainsaw idle to high
First there is an throttle idle screw that adjust the amount of throttle at idle try turning it ccw until it idles down. If this adj is at its lowest level then adjust the L screw until you get the idle you want. Then try to rev up it should rev up without hesitation if not hold down on throttle untill you get max rpm it it tries to cut out etc. at high rpm adj. the H screw until you get max rpm. then adj your L screw again for proper idle. You may need to do this back and forth for awhile until you get max. performance.
Apr 10, 2009 | Husqvarna Garden
Husqvarna 136 chain saw
Hi
high speed H=3/4 turn
low speed L=1 1/4 turn
iddle speed adjust accordingly
best regards savumihai71
Jan 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Carburetor problem
Hi
High speed H=3\4 turn
Low speedL=1 1/4 turn
idle speed t adjust accordingly.
regards savumihai71
Dec 14, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Garden Logo
537 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
