Question about Yamaha 12V Air Pump
Yamaha Waverunner won't start after seaweed
I have a YAmaha Waverunner and sucked up seaweed. The warning light came on. I stopped and removed all the seaweed. The light is no longer on, but the engine will not turn over. It sounds like it is ready, water is flowing through it, bit no go.
  • rsrbob May 11, 2010
    How do you know water is flowing through it?
5 Suggested Answers
finish line
  • 207 Answers
SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
SOURCE: My 2001 yamaha waverunner starter will not stop?
hey i just finished solving that problem by simply replacing the starter relay, located in the black electric box it cost me $40 frome rareelectrics.com my problem was that the starter kept cranking like it wanted to start my waverunner xlt1200 even if ther wer no key in it so i hope this helps i doubt that its your starter bendix
Posted on Jul 23, 2009
SOURCE: I have a 2002 yamaha waverunner xlt 1200. it will
hate to break it to you. carbs need to be rebuilt. the new fuel doesnt bode well for the carbs, clogs a really small filter and jets in the carbs
just had it done for the second time for a cost of $550/each time
Posted on Aug 09, 2009
I have a 2009 Yamaha VX Cruiser waverunner there is a very strong gasoline odor when I lift the seat to check the oil or do other maintenance I'm wondering if this is normal, I bought it used it only has...
check all fuel lines are in good condition , check fuel tank pipes etc ! run on a hose ( start engine first ) and look round for leaks ! water off then stop engine ! P...
Oct 28, 2013 | Yamaha 2009 WaveRunner VX Cruiser
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
2009 Yamaha vx cruiser waverunner used to do 55mph now won't pass 35 mph
Nevermind those other answers, if its running on all 4the cylinders but just real sluggish and missing top speed then listen up, let's first rule out the possibility of a damaged impeller, now locate your airfilter box and remove the filter, just throw it away because last I checked dirt really doesn't settle on top of water, now locate your throttle body and remove the intake tube from it, now take out the 4 bolts that hold it on and find your flame arrestor element. I've dealt with this problem many times only to find out that the geniuses at Yamaha had installed this screen right after the butterfly which accumulates airfilter material and clogs
Jun 24, 2012 | 2003 Yamaha YZ 250
I have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Sep 29, 2009 | Boating
May 15, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
625 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
