Haier HDN655E Dehumidifier
Problem for Haier HDN655E Dehumidifier
Water collection question
By carlinonj on Jul 26, 2009
I know this may sound like a silly question, but I don't want to have a mess. I have always used the drainage hose on my dehumidifier, but need to move it to a location where that won't be possible. How do I switch to using the collection bucket instead of the hose?
Solution #1
posted on Aug 01, 2009
Not Rated)
paulr621
Rank: Apprentice
Rating: 92%, 4 votes
I just bought a used one and at the rear of the unit is a black disc like "plug " which is secured by a cover. You would have removed these to hook up your hose. Simply remove the hose and reinstall the "plug" and and tighten the cover to hold the plug in place. Now when you withdraw the water container from the front , if you look towards the upper rear you will see a " U ' shaped hole . This is where the water drops into the pan..make sure it is not obstructed Good luck!
Was this helpful?
Yes
No
Popular Solutions for Haier HDN655E Dehumidifier
Questions and Unsolved Problems for Haier HDN655E Dehumidifier
Do you recommend Haier HDN655E Dehumidifier?
Answer
Answer
I have a haier dehumidifier 45 it does not have a manuel. It runs all the time - how do you set it?
Answer
the motor runs and air blows out of the back of it but no water collects in tank
Answer
I have a Haier Dehumidifier HDN655E without a manual. I can not find a manual on-line. It runs all... (More)
Answer
need to replace zener diode ZD2. I assume I would but 1.5v zener diode?
Answer
How can I fix this? Purchased at Target in Appleton, Wisconsin. Does Haier have an 800 number?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier HDN655E Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
