Question about Dell Inspiron 1525 Notebook
Hinges and top cracked on my Dell Inspiron 1525
On my Dell Inspiron 1525 the hinges are broken and the silver part of the top surrounding the screen is also cracked. How would I get this repaired and how much would it cost?
  • 164 Answers
Unlikely that its still under warranty, but you can check the warranty status at support.dell.com
you may also find parts lists on their website. The plastic bezels on laptops aren't very hard to replace.
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Posted on Jul 26, 2009
I have dell inspiron 1525 laptop , i am recently facing the problem that laptop hinges are shaking 5 to 10 mm front and back . other than this everything hardware and software are fine
the hinges screw into the laptop case. They've probably come loose through normal wear.You'll have to open the laptop case and tighten the hinge mounting screws. View or download the service manual at the following link:
http://support.dell.com/support/edocs/systems/ins1525/en/index.htm
The service manual will show you how to disassemble the laptop so you can get to the hinge mounting screws. Look under "Display"-->"Display Assembly" in the manual.
Apr 12, 2011 | Dell Inspiron 1525 Notebook
Loose Screen on Dell Inspron 1525
If the hinges are loose, it is not possible to tighten them, the hinges need to be replaced.
For details on replacing hinges, please click on these WEB sites :-
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
and these WEB sites for parts :-
LAPTOP PARTS www.laptoprepairco.com/
www.laptopparts.com.au/
www.laptopking.com/
www.lappy.com.au/
www.excelcomputerinc.com/
www.laptoprepairparts.com/
www.lapzone.com/servlet/StoreFront
www.laptoppartsexpert.com/
www.sparepartswarehouse.com/
Sep 09, 2010 | Dell Inspiron 1525 Notebook
I drop my laptop and the screen didnt crack but the clips that hold the screen broke and now the screen wount stay up. can i just buy a replacement
not a big problem you can get the hinges replaced.if screen is intact.you can get in touch with dell tech support for the same.
please make sure that every thing else is fine or there is some more damage on this.
Aug 25, 2010 | Dell Inspiron 1525 Notebook
One side of the the screen has popped out of the piece that connects it to the base
Now your hinge has broken. It can be replaced. Go to any laptop serice centres, order them new hinges for your laptop model. But it will definitely cost you some money.
May 02, 2010 | Dell Inspiron 1525 Notebook
My Inspiron 1525 laptop screen is dark on one side and also the sreen part is loose on the hinges?
Damaged inverter, or possibly loose contact / wire. If you feel confident, obtain a dismantling guide and remove the screen bezel and check the wire from the laptop to inverter and the inverter to the screen...carefully
Feb 09, 2010 | Dell Inspiron 1525 Notebook
Dell laptop broke at hinge in bottom left corner of screen.
You can buy replacement hinges here
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=inspiron+1525+hinge&_sacat=See-All-Categories
Installation instuctions are here
http://support.dell.com/support/edocs/systems/ins1525/en/SM/display.htm#wp1179838
Dec 30, 2009 | Dell Inspiron 1525 Laptop
Broken hinge on Dell Inspiron 1525
This site has the left and right side hinges, it comes as a kit:
http://www.parts-people.com/index.php?action=item&id=5377
Dec 10, 2009 | Dell Inspiron 1525 Laptop
Broken Inspiron 1525 Lid
hello
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
Broken hinge
I'd be frustrated as well. Fortunately, your Inspiron is still under warranty - contact Dell. They may send a tech to fix, or you may need to send back the laptop to them to be fixed.
Jul 30, 2009 | Dell Inspiron 1525 Notebook
Need to replace lcd screen
Sure you can, and it is pretty simple. First off, you want to remove the bezel that is between the F keys and the monitor hinges. There may be a little screw on the back side of each hinge cover, and also under the battery if the battery is below the hinges. Once you pry the bezel off, you can remove the little screws that are under the round covers on the glass side of the monitor. There should be 4 or 6 of them located on the monitor bezel. Once you remove these, you can separate the bezel on the glass side from the back of the monitor. There may be 2 or 4 screws that hold the LCD to the hinges that will have to be removed. Now you will be ready to unplug the monitor from both the motherboard and the inverter. Replace the new LCD in the reverse order.
New LCD's can be purchased from Ebay at a reasonable cost.
Mar 16, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
1,295 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
