Question about Dual Car Audio & Video
I need the wiring diagram to install an aftermarket dual stereo in a 1996 chevy lumina
    Problem Solver:
  • 9 Answers
First take out the stock head unit, after the colors of the wires originally from the car is usually red black yellow orange blue or gray, blue or gray w/ stripe, and purple or green, and purple or green w/ stripe. the head unit should have a power on it for the speaker wires those are the only tricky ones. color with stripe is negative. yellow for +12 black for -12 ground and red is for ignition, turn the radio on with ignition on. purple is usually rear and blue is usual front
Posted on Jul 27, 2009
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
Why does my aftermarket Pioneer radio blow fuses after a few minutes of operation?
what is the model of your pioneer and these luminas have the amp built right into the stereos same as the 98 same deal
Apr 15, 2015 | 1997 Chevrolet Lumina
Need the wiring diagram for a factory installed Delco/Bose audio system installed on a 93 chevy z34 lumina
1990-93 Chevrolet Lumina Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" x 6" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Jan 05, 2011 | Car Audio & Video
I had bought a dual xd1222 aftermarket stereo. i bought a gm2000 harness for it to hook up in my 2002 chevy cavalier. i have all the wires connected but when i hook it up in the carit will not work. what...
check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Sep 11, 2010 | Dual Car Audio & Video
Stereo shorting battery 1997 lumina
not sure, maybe a wire in the harness is exposed causing an arc, maybe the stereo is faulty. I would check the wires first.
Dec 18, 2009 | 1997 Chevrolet Lumina
Im trying to install an aftermarket stereo and need to know what wires to connect. need wiring diagram for 96 toyota celica gt stereo harness>
you can purchase a wiring kit that plugs into existing factory wiring for about 20 bucks saves alot of time and trouble
Sep 13, 2009 | 1996 Toyota Celica
Stereo wiring diagram
go to Walmart or Radio Shack and pick up a installer kit for your car and year and then all you have to do is plug it in the old plug in your dash and plug it in the new system and you ready to go Michigan Man.
May 08, 2009 | 1996 Lincoln Town Car
I'm looking for a wiring schematic for the electrical cooling fans on a 1996 chevy lumina car my girl let her exbf straight wire it and now its not working properly i'm sure i can fix it if i can just find...
Hello freak4style, my name is JShreader. Thank you for choosing fixya.com.
Click HERE for the Wiring Diagram for the Fan Circuit on your Lumina. I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Apr 01, 2009 | 1996 Chevrolet Lumina Mini
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Car Audio & Video Logo
229 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
