Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Remove the rear cover of washer,remove the belt, and unplug the motor lead, remove the earth wire.
Undo screws that secure the motor, and remove motor.
Brushes located at opp end to motor pulley.
Make sure that the top of the waste water pipe is at the correct height for the machine, typically around 30-34 inches from the floor (see your installation instructions). If it is any lower then it will start a siphoning action as soon as the water reaches the same level in the machine and never actually fill up and hence the cycle will not start. If the machine detects that insufficient water has entered the machine within a given time, typically 8 minutes, then if flags an error to the on board controller. If the error persists after the waste pipe height is corrected then check out the pressure switch for correct operation as if this is not triggered then the cycle will also not start or will halt almost immediately.
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer. No power Check the flex, plug wiring, fuse and mains supply for faults. Faulty on/off switch Check the power light if fitted. Replace your on/off switch. Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
