Lost daughter's retainer in washing maching, how do I open it up?
I have a Kenmore 800 series washing maching, top loading, about 8 years old.
Lost my daughter retainer in the washer, found one retainer right under the agitator, wondering if the other retainer went under the agitator. Is there any way I can look under the wash basin and under the agitator?
I pulled off the cap on top of the agitator, but not sure what to do after that?
  • drallim May 11, 2010
    It should just pull off of the shaft underneath. This is a common problem with agitators that have not been removed in some time. You may need a second pair of hands to help get it to budge. Don't yank on it, or you may have it in your face(s). It's not likely that the retainer passed into the outer tub unless the retainer shattered.
    Genius:
  • 1,140 Answers
Have to unbolt agitator to remove.
Posted on Jul 27, 2009
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
If you open lid during operation, washer fills all the way to top
if you really want to see, simply stick an object (like flathead screwdriver) into the little hole that the lid presses into to click the switch, hold it there
Aug 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore top load washing maching flipping the breaker
Maybe the breaker is going bad or you have added something else on thatcircuit
Feb 09, 2009 | Kenmore 15864/15862 Top Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
I washed some comforters and the machine will not spin . The mach
sounds like the heavy load broke the coupler. It is what connects the motor and transmission. it should still pump the water out because the bump is attached directly to the other side of the motor.
Dec 08, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
Kenmore front loading washing machine
best advise i can give is hope your warranty is still in effect.. although there is slim chance of a loose connection on control if you want to double ck remove screws on rear edge of top and remove top by sliding back and off control bd may on right front corner or on rear rail..seriously doubt daughter's boyfriend caused problem seen f01 on month old machines
Aug 06, 2008 | Washing Machines
Kenmore wash machine will not spin
Eight years is getting kind of old. When the clutch or transmission goes out, it costs more to replace the part than to buy a new washing machine. You'd better plan a shopping trip rather than spring for that $100.
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
212 people viewed this question
Top Washing Machines Experts
