Hey all here is the problem. I got the Clarion CZ109 CD Receiver AND the Ford Wire Harness receiver. Now is there anyone that could explain the proper wiring procedure? Also does anyone have all the wiring explanations for the Ford? Right now If the RED, Yellow (15a) and Yellow (3a) are connected to the FORD's RED *AND* my lights are on (required) then i get power and I can press the PWR button and it lights up but I have no sound. Im not using the Phone Mute or the 2 blue Amplifiers. Coming FROM the Ford Wire Harness, Im not using the red or yellow. Please help!!
You can pick up a harness at walmart. You have to wire your radio harness to the new harness then just plug it in. Here is a link to the harness kit.
https://www.walmart.com/ip/TOYOTA-1987-2001-CAMRY-CAR-CD-STEREO-RECEIVER-DASH-INSTALL-MOUNTING-KIT-WIRE-HARNESS/184805355?wmlspartner=wlpa&selectedSellerId=451&adid=22222222227059110156&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=163044399336&wl4=pla-268921411347&wl5=9010850&wl6=&wl7=&wl8=&wl9=pla&wl10=113137261&wl11=online&wl12=184805355&wl13=&veh=sem
Crutchfield Corporation
Rating: 4.5 - 16 reviews - $19.99 - In stock
Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
? 4:30
https://www.youtube.com/watch?v=0jqNafnki0o
Aug 9, 2013 - Uploaded by codieraji
Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet pwm 98
According to ford truck forums online, the constant battery wire may be lite green and purple, the switched power may be pink and lite green, and the ground is black and lite green. The battery wire is for memory. Is that what you need to know ?
1995 Ford Explorer Car Stereo Wiring Diagram Car Radio Constant 12v+ Wire: Green/Violet Car Radio Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: Orange/Blue Car Stereo Amp Trigger Wire: Blue (If Equipped) Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
This is because you need to purchase the aftermarket-oem harness plug.This harness plugs into your original equipment radio harness and allows you to plug any aftermarket radio into the stock deck wires.After you plug the harness in you can then connect the radio wires together.Your local autoparts store or circuit city or best buy or audio express will have these radio conversion plugs.I hope I could help
the power amp is usually under the back seat.your stereo sounds like the 2000 premium model.take the radio out and go to ford and they will match it up to get you the right info for an aftermarket harness.the ford service manual has the pin out,and you can wire it all from that data.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
trout5422 I can't figure out what that means :/ Could you expand it?
