FixYa.com
Tags:
Eclipse PA5532 Car Audio Amplifier
Eclipse PA5532
posted by Dinoscruzin on Nov 22, 2007
I don't have an owners manual for my amp and would like to know if I'm ok hooking up 4- 4 ohm speakers to the front outputs.......4 -4 ohm speakers to the rear outputs and 1- 4ohm subwoofer plus a set of 4ohm Bass Shakers under the seats. everything will see a 2ohm load and it should totally crank right! I guess what my question is ..can I put a 2ohm load on the subwoofer output and well as the front and rears with this amplifier?
Also I want to be able to control the intensity of the bass shakers so what would be a way to wire in a volume knob on the dash for them or am I just adding more resistance on the line?
I can just go to radio shack and buy a potentimeter for that?
Thanks a lot for your time and have a Happy joyous Thanksgiving!
Dino
Comment by Dinoscruzin, posted on Nov 22, 2007
Do you know where I could find a PDF Manual for this amplifier?
I have Eq's in the system Starting with an Alpine 3342 and a Phoenix Gold Bass Cube.
All of the speakers are going to be on Bass Blockers.
All five channels can handle a two ohm load with this amp? Can I go lower than that on the subwoofer channel? Or will I need to wire the two bass shakers and the one 4 ohm sub some other way so the subwoofer channel runs right?
Thanks
Dino
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Jeremiah23Pa
Rank:Master Master
Rating: 82%, 9 votes
I do think you can knowing your Amp is 5channel and 960watts,Yes you can goto radio shack for the potentimeter or goto your local audio store and buy a equalizer So you don't over power your Amp
Rating Locked! (?) Dinoscruzin has rated this solution as Helpful
Can you Help with these Car Amplifiers problems?
Car Amplifiers
car amplifiers
i have a Jeep Grand Cherokee... Answer This...
Car Amplifiers
yjhrt
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
Car Amplifiers
code for kenwood cd player
I just bought this car... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
