Question about Dell (7W036) DVD+RW Burner
Windows XP wont read DVDS and resolution sucks.
I had a virus for it so insted of fixing it we wiped the memory. now all the old sound and video drivers are no longer there. I have tried to fix the resolutin, but no luck. it reads CD's but nothing else. USB works fine and the Phone Line port is damaged. Im not sure about the ethernet port as i use wireless on the XP (im using it now) also the virtual memory is extremley low constantly and XP tells me "Virtual Memmory is too low, Windows is increasing memory. Some aplications may be denied" or something like that
    President:
  • 1,335 Answers
I assume you did not make a system recovery disk.
You should back up any important data files so that you can clean the system. Once you've completed backup, you need to do a low level reformat of your hard drive, reload XP (including updates to SR3), and use a driver update program like DriverAgent (Phoenix Technologies) to reload the latest drivers for your system, and then reload your applications. Once you have this clean system I would make a clean, full backup for recovery should this problem happen again.
Posted on Jul 26, 2009
  • 76 Answers
You will need to restore the original software installation. If your warranty is still in effect you will want to contact Dell for service, this is the best possible opportunity for a complete recovery and a happier outlook
Sony bloggie wont charge
CARLTON. invest in a new computer OR upgrade the computers memory (RAM).windows 32x max 4 GB,windows 64x 8-12 GB.is it a 32x put in 4 GB windows takes one for it system.make sure you get the right kind you have a old computer,ask a PC-dealer they should now.carlton invest in a new 12 years is old.
May 24, 2013 | Computers & Internet
Using Windows XP with a terrible, terrible video card. Will not go above 640x480 resolution. Only has 8mb video ram and Windows won't let me raise past that. Was wondering if there was any way to force...
if windows does not have the correct driver for the graphics card the resolution may be stuck at a "safe" setting, try downloading and installing a graphics driver, if the graphics card is very old and its maximum resolution actually is 640x480 there is no way other than replacing the card to achieve a higher resolution
Jul 25, 2011 | Computers & Internet
My dvd writer cannot read DVD-Video Disc,but can write all dvds
Dear i have send a some information of your problem.
i have found some links please read this carefully.
and these links are help full of you.
Thanks.
The jerky pictures and poor sound quality are most probably caused by the IDE controller (the computer has an IDE hard disk drive) not being set to Direct Memory Access (DMA) mode, which allows the DVD drive to transfer data directly to the RAM memory instead of via the processor. The alternative mode is called PIO mode, which makes use of the processor. During a DVD movie, the processor's workload gets too heavy and the stress on it makes the video become jerky and the sound quality deteriorate.
The following article should contain all of the information you need to fix the problem.
DMA reverts to PIO - http://winhlp.com/node/10
First try playing different DVDs, preferably pressed DVDs instead of home-recorded DVDs, in order to make sure that you didn't just try to play a bad DVD.
Dell used to provide Recovery CDs with all of its computers, which it still does with its business computers. You can still buy the Recovery CDs as an option during the purchase of a home computer, but for the last few years, in order to cut costs, if the purchaser doesn't buy the CDs, Dell uses a recovery partition on the hard disk drive where all of the recovery files are stored. The recovery procedure is started from the command prompt, which you can open by entering cmd in the Start => Run box in Windows XP, and in the Start => Start Search box in Windows Vista.
It would be time-consuming and difficult to describe how to remove and reinstall the DVD decoder, so Dell's support suggested the easiest method of recovery from the company's point of view, and the worse method from your point of view. In any case, the problem might not even be software-related. It could easily be caused by faulty hardware. Sometimes, even though a drive can recognise and read CDs, a hardware fault could prevent it from recognising and reading a DVD.
That said, the cause of the problem is more likely to be software-related, so, I suggest using the Windows DVD Troubleshooter. To run it in Windows XP, click Start => Help and Support. Under Pick a Help Topic, scroll down to Fixing a problem and click on it. In the window that comes up find Games, Sound and Video problems, and in the right-hand window, click DVD Troubleshooter. To find it in Windows Vista, enter DVD Troubleshooter in the Search box of its Help and Support.
This MS Knowledge Base article provides other suggestions: How to troubleshoot common problems that may occur when a Windows XP-based computer cannot read a CD or a DVD - "This article describes how to troubleshoot common problems that may occur when a Microsoft Windows XP-based computer cannot read a CD or a DVD in a disc drive. This article contains several methods that you can use to try to resolve these problems." - http://support.microsoft.com/kb/321641
If you don't have the CD that contains the DVD decoder software, it might be difficult or impossible to locate. Usually, the DVD decoder software that comes with a DVD drive or PC has a condition of its licence that it can only be distributed with the DVD drive for which it is licensed, which means that it is not usually made available as a download. Fortunately, your PC uses Sonic Solutions software, which can be downloaded from Dell's Support site here: http://support.dell.com/.
You could also try using a free 30-day trial of Cyberlink's PowerDVD software from http://www.cyberlink.com/. It is generally regarded as being superior to Sonic Solutions software and the Windows Media Player. If you decide not to buy Cyberlink's PowerDVD and uninstall it after the trial period, it leaves behind the MPEG2 codec, which allows you to play DVDs using the Windows Media Player.
If the problem is hardware-related, you'll have to replace your PC's DVD drive. DVD drives/writers are currently very inexpensive, especially when compared to the prices of Blu-ray drives/writers.
Feb 19, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
I hooked a different monitor to my HP computer and the icons and pictures on the monitor look **** comic drawings insted of sharp pictures like the old monitor. How do I fix this?
go to display properties and adjust your screen resolution: right click on the desktop then select properties (xp) or personalize (vista/7). then, in xp, go to the settings tab. in vista/7, click on display settings.
Dec 25, 2009 | Computers & Internet
PS2 wont play DVD movies!
Hi. It seems that you might have an old version of the PS2.
The original PS2's had a problem with the laser that read CDs and DVDs, often failing, creating problems with reading DVDs and in rare cases, CDs.
Unfortunately, the class action lawsuit filed against Sony is too old to get yours fixed for free, but there are ways to attempt to fix the laser yourself, if you would rather not send it in to Sony.
http://www.eurasia.nu/wiki/index.php?pagename=Ps2LaserAdjustmentAndReplacementGuide
If you have any other questions, respond and I'll help you the best I can.
Good Luck!
Nov 25, 2009 | Sony PlayStation 2 (PS2) Console
Dvds wont play on pc
You can install another DVD player software.
there are plenty of free players on the internet that you can download, or you can buy one at your local software dealer. Once you install this, the newer video codecs should be installed
Mar 12, 2009 | Dell Dimension 3000 PC Desktop
DVDRRW recognizes CDs, not DVDs.
What PC ,
HP Pavilion Media Center TV m8100n Desktop PC
what OS, we cant guess, OS, ever. say it. please.
then we can talk. it came new with XP/VISTA/W7
which one is yours? (then and now, did you upgrade to w10 for free? we cant guess that either,)
"regardless of type (DVD )" does that mean , using program manager
explorer, (my PC, my computer,app) cant see files on a real
store bought DVD? or cant read any windows disks, real install DVD? from HP or MS?
or cant read DVD-r , Only, ? be more clear on media, even give a real example .
like my computer app runs and sees it but media player don't.
ill guess XP and real DVDs can not be seen by ANY means.
if running XP , why? XP is not only a Virus magnet ask (UK hospitals that fun....)but also , has no support or is buggy on many DVD drives made. and also many USB ports and devices can be dead on XP, XP sux really... and vista close 2nd
If not on W7, upgrade it now, and win. really.
if not already.
never post lacking OS or the post will go NOWHERE fast.
there are patches for XP, for 16 long years, endless.
HP has none
MS has none, (ok 1)
you just dig them up from the toxic internet of viruses..
the toxic soup.
got SP3 from XP that is mandatory in all cases, and the reg patch for DVDs. yes, there is one.
as is the one and only, 3 month old MS patch to stop
the RANSOMEWare. attacks.
what OS what OS what OS?
May 22, 2017 | HP 5188-7537 DVD Writable CD-RW...
Ps2 will not read disc
Check your disk for scratches fingerprints ect,,
if thats all good step two
try useing a lens cleaner
****(( tip and trick for scratched disks ))****
a crayon rubbed on the disk then wiped off with a lint free cloth
no t-shirts dish towels that will just add more scratches
remember start at the center wipeing out to the edge.
if none of that works you may have a lens problem
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
Dell (7W036) DVD+RW Burner Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
