Question about Sony DSR-30 Mini DV VCR
Copying home made video from sony Hi8 tapes to Sony DV mini tapes
I am trying to copy home videos from my Sony Hi8 to my Sony digital video camera using a Dazzle Hollywood DV bridge. The tape periodically stops taping and gives me the copyrighted protection notice. These are all personal home videos. Any ideas how to keep the Sony DCR-HC21 unit from giving me this problem?
Thanks, Bob
  • 71 Answers
Sony DCR-HC21 has a multi-AV in, your Hi-8 should have a mini (4 band) to multi AV out. The cable would look like a stereo headphone cable on one end with thre RDA type plugs on the other end; red, white, yellow. The mulit in on the DV would probabaly be the same type connector. Youd have to use a coupler set for the two multi-av cables to bridge video to video and audio to audio. Come out of the Hi8 into the miniDV recorder. You should not need a Dazzle unless you want to transfer to a PC for editing before moving video back to a miniDV tape.
Posted on Jul 26, 2009
Tape stuck
DIY remove Hi8 tape stuck camcorder Check this link as it might help out to remove the cassette.
Jan 23, 2014 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder. How do I copy tape to a PC?
I'm happy to assist you with the information to transfer the videos the computer. Refer the URL to
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C353938&fes=true
NOTE: USB streaming not supported for Windows Vista and Windows 7. Instead use i.LINK cable to transfer he videos.
Dec 23, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
How can I copy a home shot movie using my Sony DCR-TRV900E to my PC? Is it possibe to copy it directly from the camera I will I need to buy something else as an intemediate step?
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Sony has a tutorial on how to do transfer to computer (Mac or PC) at THIS LINK
Nov 19, 2010 | Sony Handycam DCR-TRV900E Mini DV Digital...
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
How to copy
use s video cord or red white yellow cord to connect. camera comes with a grey adapter patch cord that will help do that easily.
May 02, 2009 | Sony Handycam DCR-TRV30 Mini DV Digital...
Software burns only 10 minutes cd
need to use a third party digital video converter....video quality will degrade while converting
Sep 18, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Copy from tape to Vcd problem
i cannot transfer videos to vcd because every time i tried keep saying error problem is i dont have the software how can i get the software from the internet
Aug 19, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
Can't use my Sony TRV22 miniDV camcorder to pass through and record Hi8 analog signal to my PC
Just below, they noted you don't put a tape in the TRV... Otherwise it outsmarts you.
Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony DSR-30 Mini DV VCR Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
