Question about Tomtom GO 920 GPS Receiver
Screen jumps back to minu have to keep tapping sceen every 5 min
  • 3 more comments
  • trevor_costi Jul 27, 2009
    this did not work
    problem not solved
    g,day
    i brought this unit on the nett, just before i left to go on a trip around aust?
    iam now half way around.
    tom tom dont bring this model into aust so thay say thay can not help me.
    so have i another choise ?/
    regards trevor
    i am i suppose looking for answer that i can fix it
    the unit is only 12 months old
    when in use in the car.
    i know i am chaseing a bream cure, but as i said iam half way around aust
    thank u for your time
    was hopeing for a dream cure i know
    so thank u any way
    Top Expert:
  • Tomtom Master
  • 80,513 Answers
The touch screen is defective, that is the only thing that will cause this problem, send it back for an exchange unit
Posted on Jul 27, 2009
  • yadayada
    yadayada Jul 27, 2009
    does this do this when it is hooked up to an outside power source or just on the internal battery? a defective battery can cause this condition due to low voltage.
  • yadayada
    look u can't fix this problem, I am sorry about that I but have researched this and the touch screen is defective if the battery ok, if there were a thing you could do then I would tell you.
  • 375 Answers
Has it got a screen protector on? If so, remove it and run a business card or thin paper under the edge all the way round as it may have a speck of dust trapped there.
The dust is being read as a screen press.
  • 15,935 Answers
The safety screensaver is enabled.
Download your manual in your native language HERE
DIRECT PDF ENGLISH LINK HERE
See PREFERENCES on page 49.
More specifically SAFETY PREFERENCES on page 50....
What happens when I use the Turn off map display option?
When you turn off the map display, instead of seeing your position on a map
in the Driving View, you will only see information about the next instruction.
Tap the button and select an option for when the map should be turned off.
These are the options:
• Always - The map will not be shown and you will only see information
about the next instruction and arrows showing direction.
• Above a certain speed - you set the speed at which point the map will be
turned off. This option is useful for situations when the map might be
distracting, such as when you are driving fast.
• Never - the map is never turned off.
Thanks for using FixYa!!
In 3-2 the tombs when my partner in i have 2 run then jump then run the last jump what do we have 2 do so we dont keep fal
First after the cut sceen rapidly tap the "A" button, wait for the on screen prompt "X" or "B" and hold that button down untill you have cleared the pit and go back to rapidly tapping the "A" button repat this for the second pit and also the third however as soon as you land having cleared the third pit you will see another on screen propmt to press the left and right triggers at the same time and hold them down until sheva has pulled chris to safty.once you get used to doing this it is probably the best level for "harvesting" with 25 gems an idol and the granade launcher.
Jan 17, 2012 | Capcom Resident Evil 5 for Xbox 360
Washer is stuck at 45 minues
Check the inlet screen on the cold water hose. Turn off the cold valve by the inlet hose, disconnect the hose from the back of the machine, and look for a plugged screen inside the hose thread nipple on the back of the machine. Remove screen, clean it out, replace screen, hose, and turn water back on.
May 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi, My lcd screen keeps going away after 5 mins of
The fact that it comes back after a tap would say to me there is a dry joint or loose connector.
http://www.technicsdjuk.com/
http://stores.ebay.co.uk/methleykev
Apr 16, 2010 | Pioneer DJM-600 Silver Professional DJ...
My screen is darker then it was when i fist got it .
Apparently you can see something, as you were able to install a screen saver. In this case, go into the control panel and check the "power options" to see if by chance the screen is set to go to black in 5 minutes. If so, change the value.
If this is not the problem and you can't brighten the screen with the screen controls, try an external monitor to see if the video is OK.
If it is, then you are looking at the power supply or the flourescent bulb in the monitor being bad.
Sep 25, 2009 | Acer Aspire 5610-4648 Notebook
Apple iPod Nano 2GB MP3 Player software
i had the same problem.... what i did was..pluge the ipod to the comp & restart then wait for 10 to15 min.
Jun 20, 2008 | Apple iPod nano
Ford cd codes
Dear Customer,
Actually what ever you read from cd system for waiting but dont depend on what you get on screen cause some time screen may wrong with actual performance,so check your display sceen & try to do funn with your favourite cd's with care,
THNX
May 17, 2008 | 2000 Ford Focus
Television picture gets larger
Your problem most likely is in your high voltage circuit, and the 160 volt radial lead capacitor is probably gone high ESR or changed in capacitence, this usually happens during bright sceens or sceen change.
May 24, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Tomtom GO 920 GPS Receiver Logo
66 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
