Question about Sony KDF-E60A20 60 in. LCD HDTV
THE SCREEN AND SOUND COMES AND GO EVERY 30 SECONDS AND THE POWER INDICATOR LIGHT IS BLINKING ON RED FIVE TIMES
  • prrefri Jul 30, 2009
    the fans are working fine!! what could be the next item to check?
    Brigadier General:
  • 8,619 Answers
Hi
This error means that one of the fans is NOT spinning! To check.... unplug the tv.... turn the TV around to a well lighted area so that you can see the fans in the back... plug the TV in and turn it on. Watch for the fans in the back... and see if they are spinning. If not... that is the reason why the TV will not turn on! It could be the fan next to the lamp was stuck for some reason. Remove the cover of the TV from the back... and clean the fan, also make sure all connectors to it are properly connected.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 27, 2009
  • Rylee Smith
    Rylee Smith Jul 30, 2009
    Hi
    If the fan is perfectly fine then this is happening because AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
    After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
    Thanks
    Rylee
Kv sw212n50
Five blinks to Sony Wega denotes a fault to its AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 01, 2013 | Televison & Video
I have a Sony KF 50 WE 610 projection screen TV. It has worked perfectly since I bought it six or seven years ago. This morning I turned it on and the sound came on for a second, but then the sound went...
Hello
Five consicutive blinks at a time and the stops and again blinks five; is its self diagonosis procedure. All modern Sony sets has this function included in its circuits. If the system control IC inside it detect any fatal fault inside its circuits system, it will give a signal to its power control unit to shut it down its high voltage outputs to protect the other components from further damage. In your set; as Sony describes; I quotes:-
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Actually the components marked in numberes will not be the same as in your TV. But the fault will it be.
    If you have enough knoledge in electronics and have a concept of soldering and have a good quality multimeter; youreself can do this work by home. OK
    Mar 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
    I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
    Mar 09, 2011 | Sony Televison & Video
    KV32CS76E red light blinks 5 times again and again totaaly blank screen
    Feb 02, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
    • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
    Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
    Sony kv28dx30u: Sound comes on, but picture doesn't for a good ten minutes or so. The pilot light flashes red 5 times. persumably its an AKB problem. Is there a cure for it? Thanks.
    That means the tube is getting weak and a tweak of the A1 control could help.
    Jan 15, 2011 | Televison & Video
    Picture & sound go on & off every sec, red light blinks 5 times
    helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
    shaun
    Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
    BRAVIA KDL-V32A12U PICTURE LOSS
    THREE Blinks
    B+ over voltage protection (OVP), unit goes to the standby
    mode then displays the 3 blink fault. This is also a problem in the power
    supply circuit, check T603 and R672.
    FIVE Blinks
    AKB circuit (AKB), the timer/standby indicator blinks for about
    30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
    Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Sony KF-60WE610 Screen and Sound On/Off
    All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
    Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
    Just sound
    FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
    Feb 26, 2008 | Televison & Video
    Sony KDF-E60A20 60 in. LCD HDTV Logo
    32 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
