A L portable speaker for Ipod will only work when Ipod is place on connector without the cradle and held forward
  • ronfryer1 Jul 26, 2009
    Thank you for your reply but I do not know what the connecting wire tabs are
  • 15,935 Answers
The connecting wire tabs are out of alignment.
Take a pin and bend them out lightly to re-locate them to the correct location.
Thanks!
Posted on Jul 26, 2009
  • blueextc3221
    blueextc3221 Jul 27, 2009
    In the cradle there is a connector - there are pins that mate with the ipod. One part is solid (ipod) the reciever has pins - that get bent if the ipod isnt cradled properly.
    Aftermarket products rarely mate well with IPODs
    If the pins are inacessible - your dock is now a paperweight.
    An alternative is to attach foam tape to the required thickness to "auto" tilt it when it is in the cradle.
Need to take the ios cradle off lazer tag blaster - to play without ipod
Easy, Long nose pliers to the inside bottom of the cradle.
pull and hold the lock ( the little thing sticking out, looks like a notch), and pull out the cradle. easier to do if the cradle is closed up and no iphone
Mar 14, 2013 | Hasbro Lazer Tag Blaster
On the Logitech mm50 Portable Speakers for iPod, the + volume button plastic cover has fallen off. Can I fix it myself?
Glue will not usually work---use something not sharp like a plastic wand to activate the micro switch---as far as the buttons they are usually a one piece part that is either melted in place or screwed--may be a little hard to locate.
Jun 10, 2012 | Logitech Inc MM50 Portable Speakers iPod...
Why Does my speaker make my ipod shuffle
You need to use the correct cradle that came with your JBL speakers.
The reason for your problem it's "vibration" from, it makes your Ipod vibrate off the cradle just enough to shuffle your music.Try it let me know
May 23, 2012 | JBL On Stage Micro II Speaker Dock for...
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
Charging
Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
May 24, 2010 | Logitech Pure-Fi Express Plus...
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
To plug the sistem in Ipod...
Hello there
First things first:
1) you can use all speakers with the iPod..
2) what kind of iPod is? Nano? Shuffle? Classic? iTouch?
3) use regular iPod connector to place on right jack.
good luck
Jan 24, 2008 | Creative Labs SBS 450 Computer Speakers
Ipod wont work
The problem is "ipod dock receiver connector"(connector is fuck), move forward and backwards the ipod just point the ipod can play the songs..
try you!
Dec 25, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Ipod Nano 2nd Generation won't charge on Boombox
try you!
Nov 25, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Portable speakers for ipod mm50
i can not understand your problem.
please rell me more.
Nov 24, 2007 | Logitech Inc MM50 Portable Speakers iPod...
18 people viewed this question
 Grubhead
Grubhead
