Question about Brother LS-1520 Mechanical Sewing Machine
Instuction how to thread machine properly.
I've misplaced my instructions, and I doing a project at this time, I haven't used my machine for sometime and I forgot how to thread it. The printed guide on the front of the machine really is not helpful. Would you send me instructions how to thread and put the bobbin in the caseing so it doesnt bunch. Im working on tule, what did I set the tenstion too, thanks in advance for your help. P.S. I just ordered a instruction guide but I'm working on a project now that is due tomarrow.
    President:
  • 2,559 Answers
Here is a picture,I can email the manual as well if you supply an email address.
Posted on Jul 26, 2009
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
How do I adjust the tension for straight sewing?
First, be sure you are using a brand-new needle and that the needle, thread, and fabric are compatible.
All About Needles
When you thread the upper thread, be sure the presser foot is ALWAYS RAISED so the thread will seat properly in the tension disk. Also, confirm that the machine thread pathway is correct.
Remember that when fabric types/weights are changed, the needle/thread should be changed accordingly. (Needles should be changed often to attain the best sewing experience and minimize unnecessary frustration.) The tension may also need to adjusted. Tension is not static. It should be adjusted to fit the project being sewn. Unless one continuously sews with the same fabric, thread, and needle type would the tension adjustment remain at the same setting, but machines do change over time so a tension setting that worked last year may not look the same this year.
The factory standard tension setting is the midway point between the high & low numbers. However, please understand that machines vary and that sometimes this standard setting may change with time and use. The midway point should only be the beginning point and is most likely suitable for medium-weight fabric. Also, usually the bobbin tension does not require frequent adjustments unless a particularly heavy- or light-weight thread is used in the bobbin--sometimes the bobbin tension will get out of whack requiring adjustment (consult the owner's manual or search the internet for instructions for adjusting bobbin tension). In the majority of cases, the tension adjustment is made to the top thread.
Test your straight stitch on your fabric (may be helpful to use a different color thread in the bobbin so it is easier to see any tension issues). If the bobbin thread is popping up to the top of the fabric, loosen the upper thread tension. If the upper thread is looping or showing on the bottom of the fabric, tighten the upper tension. Keep adjusting until the upper and bobbin threads meet in the middle of the fabric.
FWIW, the same process would be used for zig-zag stitching. Just make sure that the tension is not too tight or it will cause the fabric to pucker (or tunnel).
Mar 07, 2016 | Sewing Machines
My Bernina Activa 140 (12 yrs. old,first time to have any trouble with it) has stopped stitching properly. The top thread looks normal but underneaty(the bobbin thread I guess) is just giant loops an
Almost every time this will be due to the machine being not threaded correctly. I've been sewing for 45 years and still mis-thread my machine occasionally. It's also possible that the bobbin thread didn't seat quite right when you put in the bobbin. Or, I've had mine do that if I didn't quite get the presser foot lever down completely. (working with heavy fabrics usually)
If that is not the case here, try replacing your needle with a new one, as it might have developed a small burr, and be certain that it's the correct needle for the fabric. Sometimes it can also be that the needle is in backwards. Also, cleaning it, (the bobbin area), out thoroughly by using a soft brush and some canned air can do wonders for it. Then use a drop or two of sewing machine oil where your manual indicates it to go in that area.
If none of that fixes the problem, let me know and I'll see if there is a problem specific to your machine that can happen.
Happy Sewing! :)
Oct 27, 2012 | Bernina Activa 140
On my Singer 8280, the thread stitches are very loose. I've tried adjusting the tension of the upper and below thread. No change, still loose stitches. Any ideas? I wonder if I broke and...
The most common cause of this is improper threading.
1. Thread the upper thread properly with the presser foot in the UP position.
2. Make sure the bobbin is threading with the thread unspooling in the correct direction.
3. Make sure the needle and thread are suitable for the fabric in your project.
Watch this video.
Oct 14, 2012 | Singer 8280 Mechanical Sewing Machine
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
Haven't had the Singer Sew Simple very long. Second time to use it. Ready to throw it out the window. Bobbin tension seems to be off. Thread keeps knotting up and breaking under fabric, jamming the...
Have you tried re-threading it? Remember to keep the presser foot up as you thread so that the tension discs are open. Re-thread the upper thread because it can often cause bobbin jams.
Perhaps your tension discs are blocked, try running a thicker thread through by hand to clean them.
Check there are no broken threads in the bobbin raceway.
Sometimes the wrong size needle upsets the tension.
Sep 15, 2011 | Singer 3116 Simple
Bobbin placement we cant get in correctly and it wont pick the bobbin thread up. when trying ti sw it bunches in knots and breaks sometimes
Sounds like the bobbin may not be the right one for your machine. YOu haven't said what make and model this is but you should check your manual or online to ensure you have the correct bobbin for it. I've seen Elna's with Singer bobbins in, they'll stitch okay but then tension problems occur, you need to have the right one for your machine. (if you aren't sure, try looking at www.sewusa.com or www.sewingpartsonline.com to find the bobbin described for your machine.)
Also metal bobbins can get squished if they've been stood on, so have a good look at it and make sure the bobbin is in good shape and looks okay.
Now take the thread off it and rewind a fresh bobbin making sure you've got tension on the thread the whole time and that the thread winds onto the bobbin very smoothly and evenly. This is something that is not emphasied in sewing machine manuals but makes a HUGE difference. Think of your garden hose coiled onto the hose reel. If you wind as the hose wants to go, it goes onto the reel all over the place, then jams up and you can't get it all on there. Look at how a thread spool is wound, the factories wind the thread in a very neat sequence and you want your bobbin to look the same. So always use the tensioner on top of the machine to take the thead around when winding the bobbin. If you don't have one, then put tension onto the thread spool the thread is coming off to ensure the thread runs off at a constant tension and speed.
Carefully watch the thread as it goes onto the bobbin and nudge it with your fingertip to get it to fill evenly top, bottom and middle of the bobbin. Stop when 3/4 full.
Now put bobbin to bobbin holder ensuring that it goes in the right way, always the thread should come off the bobbin and reverse direction in a V shape. Click the thread into the tension spring. Double check it is in there and then thread up the rest of the machine and test sew.
THere is some good trouble shooting tips at www.sewusa.com so this might help you also.
Sep 14, 2011 | Sewing Machines
Brother LS-1520 Mechanical Sewing Machine Logo
342 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
