Question about Standard (CRT) Televisions
Programming and storing channels
I have a problem storing the channels on an RCA Television.
I purchased the set for my mother about 12 years ago, so of course the manual is nowhere to be found.
I run the auto program function on the set, but it doesn't seem to work/store the channels. Any help you can give would be greatly appreciated.
PS: If you could some how get me a copy of a manual would really be great.
Thank you.
C. Glover
5 Suggested Answers
  • 298 Answers
SOURCE: Remote not fully functional
You can get an original remote for this model at these following links:
Philips 30PW9100D Replacement Part Remote Control
Philips 30PW9100D Replacement Part Service Remote
Posted on Dec 26, 2008
  • 49 Answers
SOURCE: Memorex MT2024 programing
OK, I and many others have had a problem using this TV with remotes that are not the original (i.e. universal remotes). I have Comcast cable and the remote they gave me with the cable box will operate most of the functions of the TV, but the volume down botton always brings up the TV setup menu.
I solved this by purchasing the Phillips SRU4208WM/17 remote at Wal-mart and teaching it the functions of the original remote by using the Learning mode.
It works great now. Volume up and down, channel up and down, etc.
Posted on Dec 30, 2008
  • 20 Answers
SOURCE: my tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
Posted on Jan 02, 2009
  • 5 Answers
SOURCE: turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help.
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Posted on Feb 04, 2009
SOURCE: AV channel on magnavox tv
This worked for my 20" Philips Magnavox 20MT4405/17 TV, it might work for you as well. DISCLAIMER: This is just a solution that I pieced together information from various internet sources, as I could not find a free copy of the service manual to verify this. Furthermore, I am not a technician of any sort.
Enter your TV's service menu by pressing this sequence of buttons on your remote while the TV is on:
062596 Menu
Use the arrows on your remote to scroll down to "Options", push the right arrow to enter options.
Change the 7 options parameters in order to (write down the original values in case this does not solve):
OP1: 065
OP2: 215
OP3: 065
OP4: 162
OP5: 204
OP6: 201
OP7: 000
You need to enter all 3 digits for every number, even if there are zeroes. You use the numbers on the remote to do this.
Turn the TV off with the built in power button.
Unplug the TV for 10 seconds.
Plug the TV back in, turn it back on.
If this does not solve your problem, reset the values of the options in the service menu to the values you wrote down earlier because you have a different problem than what this fix works for.
Posted on Mar 18, 2010
0 characters
1 Points
How to change the channels manually on a rca colortrax 2000 television
Set should have up down buttons---only a few models had all only on the remote and set has to have the channels programed into it for this to work.
Mar 16, 2012 | RCA Standard (CRT) Televisions
Hello my mother's rca tv is stuck on channel 91. when i turn it on and use the channel keys on the set, they don't change the channel. i'm trying to get it on channel 3 so she can watch her cable.
Press Setup until you see AutoProgram... press Volume ... you will see the channels start to change. It will cycle to ch 62 or so, then go back and do the lower channels. as soon as it hits 3, quickly press Setup. it will stay on ch3, if not do it again. Once you get it on ch3, press setup until you see Channel Add/Del ... press Volume to add it. Press setup until screen is cleared. Ch /- should now toggle between 3(cable) and 91(a/v in)
May 17, 2010 | RCA Standard (CRT) Televisions
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Program RCA F20352SF television to DVD player
I just bought the same TV second-hand and had the same problem. Solution: Use remote to change channel to 00. You can't display channel 00 using front panel - a remote is required. I have a very basic RCA universal remote, & it does the trick.
Aug 11, 2009 | RCA F20352SF TV
Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
Mar 22, 2009 | Standard (CRT) Televisions
Finding out what my AV/INPUT channel is
Greetings Debjake,
Looking at similar models from Toshiba, there should be a Tv/Video button on the front of your unit. If your television doesn't have the component (red/white/yellow) connections and are connecting through the coaxial antenna jack your input channel could be either 3/4.
Go Ahead. Use Us.
May 27, 2008 | Standard (CRT) Televisions
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Standard (CRT) Televisions
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Apr 07, 2008 | Standard (CRT) Televisions
Purchase of the RCA F27252GY 27 INCH TV
My set of the same model shows a build date of 1998. New 27 inch basic sets sell for 100+/- on sale at varius stores. I'ld say the value is no more than $25. for a 9/10 year old working table model TV
Nov 16, 2007 | RCA F27252GY 27" TV
Only receiving Channels 50 and above; no lower channels
It could be anything from corrupted data in the EEPROM (a memory IC that stores all the channel information and picture settings) which is usually caused by bad ground solder connections inside the tuner itself which is built into the main circuit board and would have to be repaired, not replaced or components inside the tuner section of the main PCB. With that being said - if you have to get a technican to come to the house and repair the set then it would probably be best to buy a new HDTV set. If you can take it to a repair shop capable of fixing the tuner, it could cost close to $200 to repair is my guess, and may work OK for another year or two before the picture tube finally wears out.
Dec 28, 2006 | RCA F35673MB 35" TV
Standard (CRT) Televisions Logo
119 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
